Zenith 6S??? 1938 Tombstone
12/28/1999 7:19:35 PMPaul Edgar
My Zenith Black dial, serial number R323950 , according to oldradios.com is a 5644a chassis, and could be a 6S249, 6S254 or 6S256 .
I know the 6S254 is a console, so it must be a 249 or 256.
Can anyone help with a schematic ?
Regards Paul
12/28/1999 8:01:04 PMNorm Leal
Hi Paul
I'll send you the schematic for Zenith 5644A chassis. The 6S254 and 6S256 are both consoles. The 6S249 is a chair side. Your serial number matches the chassis. Does it look like someone replaced the chassis in your tombstone? Is there any numbers on the cabinet?
: My Zenith Black dial, serial number R323950 , according to oldradios.com is a 5644a chassis, and could be a 6S249, 6S254 or 6S256 .
: I know the 6S254 is a console, so it must be a 249 or 256.
: Can anyone help with a schematic ?
: Regards Paul
2/17/2009 9:34:18 PMRay
Hi, I would like to obtain a copy of the Zenith 6S254 Schematic.
Right now, I'm cleaning the radio up, inside and out. The radio plays, a little hum, not bad for 70+ years! Would like to see if I can increase the sensitivity a bit, it receives about 20 stations with a 75' antenna.
Ray
Hi Paul
: I'll send you the schematic for Zenith 5644A chassis. The 6S254 and 6S256 are both consoles. The 6S249 is a chair side. Your serial number matches the chassis. Does it look like someone replaced the chassis in your tombstone? Is there any numbers on the cabinet?
:: My Zenith Black dial, serial number R323950 , according to oldradios.com is a 5644a chassis, and could be a 6S249, 6S254 or 6S256 .
:: I know the 6S254 is a console, so it must be a 249 or 256.
:: Can anyone help with a schematic ?
:: Regards Paul
2/18/2009 10:01:46 AMDoug H
Try the following links:
http://www.nostalgiaair.org/PagesByModel/212/M0025212.pdf
or
http://techpreservation.dyndns.org/schematics/38/38_Zenith_6-S-254_225.djvu
Doug
:Hi, I would like to obtain a copy of the Zenith 6S254 Schematic.
:Right now, I'm cleaning the radio up, inside and out. The radio plays, a little hum, not bad for 70+ years! Would like to see if I can increase the sensitivity a bit, it receives about 20 stations with a 75' antenna.
:Thanks,
:Ray
:Hi Paul
:: I'll send you the schematic for Zenith 5644A chassis. The 6S254 and 6S256 are both consoles. The 6S249 is a chair side. Your serial number matches the chassis. Does it look like someone replaced the chassis in your tombstone? Is there any numbers on the cabinet?
::: My Zenith Black dial, serial number R323950 , according to oldradios.com is a 5644a chassis, and could be a 6S249, 6S254 or 6S256 .
::: I know the 6S254 is a console, so it must be a 249 or 256.
::: Can anyone help with a schematic ?
::: Regards Paul
