I have an L'Tatro 6V farm radio I THOUGHT was a 00-66 but the tube line up is different with only four tubes. Mine uses 1C6, 1A4, 25S and a 1F4. The ID sticker is worn but the serial #10443 is visible. Any help here?
4/8/2005 6:01:06 PMStevet(30163:30138)
:I have an L'Tatro 6V farm radio I THOUGHT was a 00-66 but the tube line up is different with only four tubes. Mine uses 1C6, 1A4, 25S and a 1F4. The ID sticker is worn but the serial #10443 is visible. Any help here?
I recently obtained a similiar radio, and I had to trace it down. The 25s tube is the same as a 1b5, and that fits the tube line-up for a model EN6-4, which was the only model I could find that used that tube line-up. Hope this helps.
