Any thoughts are greatly appreciated!!!
:Clair,
:Wire sizing and number of turns etc is the easy part. Is the original power supply capable of the additional load, and if so, it might be simpler to parallel the field coil connections with the appropriate value of 10-20 watt resistor, unless you are an absolute purist.
:Additionally, the resulting voltage can be higher with this reduction in resistance, and could affect capacitors beyond the field coil. I have the experience of only one field coil rewind, (about 15000 ft) but the experience is well documented.
:marv
::I have a Zenith 12 tube speaker(12s265) that I would like to rewind. I have been doing research and found so many different ideas and procedures on figuring out what kind of wire and what size. I would like to rewind the original 670ohm field coil to approx 300ohms. I intend to use this 12" speaker in my 15 tube zenith(275ohm field coil). I know there is a significant current increase from the 12 tube to the 15 tube radio. I am concerned about the gauge of wire. What do you suggest using and how much wire? I am new to rewinding coils and there is almost no possibility of me finding the original speaker(Part number 49-187), that is why I want to rewind the coil.
::Any thoughts are greatly appreciated!!!
Placing a resistor in parallel with the original 600 ohm field coil is a great idea. It will eliminate a bothersome rewind. What must be done is the original voltage drop across the 600 ohm coil in its original radio must be established. The voltage created across the field is critical as it determines the amount of magnetism created by the field. Then what you do is place the speaker in the new 15 tube radio with a resistor in parallel with the field to creat roughly 275 or 300 ohms total resistance. After that measure the voltage across the field in the new radio with the resistor across it. Hopefully the voltage will be the same due to the higher current draw of a larger tube count radio. If it is lower, try increasing the resistance in parallel. It cannot be increased too much, as this will cut down on power available to the radio. Try to get both the voltage across the field and the voltages in the radio after the field to be correct. If this cannot be done, then the field coil must be rewound to 275-300 ohms.
My first order of business is getting a working field coil speaker. Does anyone have any ideas or suggestions?
Any thoughts on either rewinding or knowing anyone who is the best at doing this?
:Ah. You didn't mention that it was open in your original posting. The resistor idea would only be practical if the 670 ohm field coil worked still. It would eliminate the need for a rewind. If the 670 ohm field coil is open, though, you are better off just winding it for 275 ohms and dropping the resistor idea.
:Thomas
:Thomas
