Philco 38-7 Console
12/26/1999 11:30:14 AMJohn Hudson
We have acquired a Philco Console. It appears to be in good
shape. It lights up when turned on. (I just read that I should replace
the Caps before doing that!). Suggestions about where to obtain parts, help with
restoration of this fine old machine would be appreciated. Thanks in advance.
John
12/26/1999 12:08:37 PMNorm Leal
Hi John
I'll send you the schematic by email. It's important to replace electrolytic filter caps, items #11, 11A and 45 on the schematic. These will go bad over time and can damage other components in your radio.
You can get parts from Antique Electronic Supply, tubesandmore.com . They will have just about anything you might need. Check antiqueradios.com/resources for other companies with parts.
Post your questions here. It shouldn't be too hard to repair the radio as long as you can use a meter.
: Hi,
: We have acquired a Philco Console. It appears to be in good
: shape. It lights up when turned on. (I just read that I should replace
: the Caps before doing that!). Suggestions about where to obtain parts, help with
: restoration of this fine old machine would be appreciated. Thanks in advance.
: John
