General Electric H77 Radio
3/26/2005 2:01:01 PMErnie Swartout
The above radio is about to drive me nuts. The circutry appears to be ok, the various voltages are as they should be. My problem---when I plug the radio in I get the local radio station regardless of where I have the station selector. Not only that, I get it with absolutley no antenna. What have I overlooked?
3/26/2005 6:21:29 PMNorm Leal
Hi Ernie
Check the oscillator circuit around your 6SA7 tube. When the oscillator doesn't operate sometimes a radio picks up one strong station. Only volume will change by tuning.
When the oscillator operates pin #5 will be several volts negative. If it's not check voltages on the 6SA7 and continuity of the coils. Try another tube even if it tests ok.
:The above radio is about to drive me nuts. The circutry appears to be ok, the various voltages are as they should be. My problem---when I plug the radio in I get the local radio station regardless of where I have the station selector. Not only that, I get it with absolutley no antenna. What have I overlooked?
4/8/2005 11:46:54 PMErnie Swartout
:Hi Ernie
: Check the oscillator circuit around your 6SA7 tube. When the oscillator doesn't operate sometimes a radio picks up one strong station. Only volume will change by tuning.
: When the oscillator operates pin #5 will be several volts negative. If it's not check voltages on the 6SA7 and continuity of the coils. Try another tube even if it tests ok.
::The above radio is about to drive me nuts. The circutry appears to be ok, the various voltages are as they should be. My problem---when I plug the radio in I get the local radio station regardless of where I have the station selector. Not only that, I get it with absolutley no antenna. What have I overlooked?
4/8/2005 11:51:50 PMErnie Swartout
Norm,
Thanks for the advice, I tried it and it didn't solve the problem so I must have something else wrong.
Ernie
:Hi Ernie
4/9/2005 1:12:51 AMBill
I can't tell too much from the schematic, but you need to check L1. This very same symptom I've noticed when a wave trap got messed up bad on similiar GE set I have. My problem could be something else tho as I haven't devoted any more time to check it. Ticked off because I messed it up, careless. Set will set until I can get over it. I'm moody sometimes nowadays.
:Norm,
:Thanks for the advice, I tried it and it didn't solve the problem so I must have something else wrong.
:Ernie
::Hi Ernie
:: Check the oscillator circuit around your 6SA7 tube. When the oscillator doesn't operate sometimes a radio picks up one strong station. Only volume will change by tuning.
:: When the oscillator operates pin #5 will be several volts negative. If it's not check voltages on the 6SA7 and continuity of the coils. Try another tube even if it tests ok.
:::The above radio is about to drive me nuts. The circutry appears to be ok, the various voltages are as they should be. My problem---when I plug the radio in I get the local radio station regardless of where I have the station selector. Not only that, I get it with absolutley no antenna. What have I overlooked?
