Tube voltages measure good except some grids at -0.15 vs. -0.5 volt. Tried substituting 6AG7 and 6BE6 front end and osc/conv, no change. Raised AC voltage to 135v through Variac and a few more stations up to about 96MHz are tunable (and audio is higher), but the plate voltages are over the Riders spec'ed values when I do this.
Looking for additional troubleshooting ideas. Thanks,
Craig S
-Craig S
___________________________________________________
:If you get more stations by raising the line voltage, have you checked for a weak tube, drifted resistor, or leaky condenser? Disconnect resistors and condensers before testing them. Condensers should have no leakage, not even in the millions. These sound like the most likely, because they are what would cause the oscillator to malfunction.
:T.
T.D.
:Thanks, Thomas - I did check the RF amp and Osc/Conv tubes, and replaced a paper bypass cap on the RF amp, but will check the other R's and C's and see if there's a leaking cap or bad resistor in there.
:I also should have noted that the plate supply voltage decreases slightly as I tune from low end to high end of FM band (92 volts to about 88 volts).
:-Craig S
:___________________________________________________
::If you get more stations by raising the line voltage, have you checked for a weak tube, drifted resistor, or leaky condenser? Disconnect resistors and condensers before testing them. Condensers should have no leakage, not even in the millions. These sound like the most likely, because they are what would cause the oscillator to malfunction.
::T.
T.D.
:I guess I can just answer my own questions by looking at the schematic. It's AC/DC, and 90 volts is the approximate voltage to be found at the RF plates, so 92 to 88 volts is alright. Still check things to be sure. If resistors are not more than 15% off, don't worry about them.
:T.D.
