You could replace with 1N4007 diodes.
: Doug, AC in and DC out. My analog meter shows somewhere around 150 dc. I did the test with negative lead on the chassis. Seems like alot but I really don't know.
Is this an AC/DC set? I couldn't find any reference to the Zenith model no. you listed.
:Doug, I did some further investigation. I found a 39 Ohm resistor shorted between a 12au6 and 12ba6. Both I guess are RF Remote cutoff pentodes. I'm not sure where to get a 39 Ohm resistor (orange, white, black, and silver). Would this be a 35 watt resistor? Ceramic? Looks like a common one to me. Tube shaped and about 3/16 by 1 1/8. The label on the radio says 35 watts. I did find a chassis number of 7c06. Maybe this will help identify this rig. I don't have a schematic or specs. Just shootin in the dark as a layman. Any thoughts?
Herman
I fear that you've bitten off a little more than you can chew, at least for now. If you're just starting out, I'd recommend starting with a simpler set, an AC/DC 5-tube, post-war reciever. There are several basic books on antique radio repair and electronics that would be good to study - you can search on Google or Amazon.
Thanks Doug, I did finally find a schematic. You are correct in the resistor value. This rig takes a 39 Ohm, 1 watt, wire wound. I think I'll give that a try then move on to something else. Thanks for all your suggestions and advice.
73
Herm
