Silvertone Wire Recorder Radio Record Changer.
3/7/2005 11:04:11 PMLinda Porter
I recently came into possession of the above item. Beautiful piece of furniture but do not know if works. Am in process of cleaning, checking wiring and tubes. If I need tubes, do you know a source? I have all books and manuals, parts lists and such that came with unit. Any help appreciated.
3/8/2005 9:21:11 AMR Meyer
www.tubesandmore.com or www.vacuumtubesinc.com. are the two I use the most. There are many more out there these are just two good sources. Jim at vacuumetubesinc will take calls and answer questions also.
3/8/2005 9:27:15 AMThomas Dermody
www.tubesandmore.com, eBay, and you name it...you'll find tubes at a lot of places. A lot of guys on here have other sources that I am not aware of, but are just as good.
If you don't have any wire to play, you can simply draw a thin bladed screw driver across the playback head while the unit is set to "play." It should make a popping noise in the speaker. A steel sewing needle will be just as effective. It is not wise to play wire on one of these units until it has been thoroughly gone over. The parts must be lubricated with precision, and the stopping brakes must work well. If they do not, when you stop the machine the spools of wire will continue to spin, and your music will be ruined in a tangled ball of wire. When working on a machine like this, it is best to use a spool of wire that you do not care about. Then, when you play pieces of interest after you have gotten it working, record them imediately on the first try (record onto CD or cassette or reel to reel). This way you will have the pieces recorded onto a less delicate medium. After they have been recorded, you may play the wire recordings as many times as you wish, and though it would be a shame if they tangled, you will not lose the music.
P.S. There's a lot more to repairing the electronics of the machine than just the tubes, but the above source former will sell all of the components you will need.
