From the schematic you have it right. The 10uF positive side goes to B-. The 16uF positive side goes to the IF primaries and the speaker.
Mike M
:hi i am trying to get a coronado mod. 962 going the electrolytics were missing it has a 10 uf and a 16 uf i have hooked the positive end to the b- and on the 16 uf i hooked the positive end to the field coil and the ifs is this correct ?this is a battery set so far all i get is a little pop out of the speaker for a second when i hook up the b+ i thought maybe i not hooking the electrolytics right. butch
:What schematic are you guys looking at? The schematic I am looking at (top one listed for 962, which is in fact the 962), is a battery operated set. The speaker in this set, as I see in the schematic, does not have a field coil. The 10 MFD condenser should be connected with the positive side going to A-, or the chassis, and the negative side going to B-. The 16 MFD condenser should have the positive side connected to B+, and the negative side connected to B-.
:Thomas
It is extremely hard for one to shake off the false understanding that ground is always the most negative or neutral item (take, for instance, a positive ground car, in which the positive side of the battery is connected to the chassis). I am saying this from personal experience, as throughout my life others have always explained the notion of ground to me in an incorrect manner. I cannot properly explain it, myself. I do not have words to explain it properly as it is very conceptual. Perhaps with much thought I will someday. Ground, though, is simply a common reference point. The "neutral" wire in your house is neutral because the center tap of the transformer outside of your house is connected to both it and ground. Some people also refer to this wire as the "cold" wire. Since this is alternating current, there is no actual polarity. It just so happens that because this wire and ground are both at the same potential, you won't get a zap between the two of them. The same holds true with antenna circuits. The only reason why the Earth ground plays any role in radio reception at the receiver is because it is also part of the antenna circuit at the transmitter. It will only reference wherever it is placed. It does not have a specific reference point other than that which it is placed in a particular circuit (house, antenna, radio, etc.). You can think of the chassis in your radio in the same way as you think of Earth ground.
On a radio you will find that the chassis, often referred to as ground, is a common place for many components to connect to that require a certain voltage at this particular reference point. For negative grid bias of say the output tube, many radios will place a resistor from the chassis to the cathode of the tube. This will make the cathode more positive than the chassis, thus making the grid of that tube more negative than the cathode. Other radio designs, such as the one in question here, put a resistor in series with the chassis and B-, and connect all items that must reference at the chassis voltage to the chassis. Anything before this resistor, though, will be more netagive than the chassis. Grid biasing resistors may be tied here (as are in this particular schematic), which will effectively bias the grid more negative.
Sorry for getting overly complicated, and I don't know if this one makes sense at all as I explain it, anyway. Should it not make sense, disregard it and perhaps someone else will explain it better in the future.
Ground is just a reference point, it can be positive or negative in relationship to the other voltages. Now, how is that for simple!!
hi you are right thomas there is no field coil bat. sets never have them anyhow i meant to say the the primary of the output xformer or at least that is what i should have meant.however i seem to have them right so i guess i'll have to look elsewhere for my prob.i am using 10 9 v. batteries for b+ i know they won't last too long but i should hear something at first i heard a lot of microphonics then i changed one of the 1q5s and haven't heard anything since except a very short noise when i first hook up the batteries then nothing i will check plate v. next thanks for all the input. butch
hi thomas somewhere i found a plan that uses a gell cell or nicads 6v. you then use a a switching device and xformer to make a rechargable power supply of 90 v. and 6 v. filament but as i remember it was too complicated for me.i like your idea better i can afford it as i am a plumber and you know what ripoffs plumbers are. ha ha. butch
