:HEY GUYS
:I HAVE A ZENITH 5F134 THAT DOES NOT HAVE THE VIBRATOR SUPPLY UNIT WITH IT. THE SCHEMATIC SHOWS THAT WHEN YOU USE CERTAIN BATTERY TYPES YOU EITHER USE VIBRATOR SUPPLY UNIT, OR JUMPERS, OR BALLAST TUBE. IS THERE A WAY TO CONVERT TO 110 USING SAME TUBE CONFIGURATION, AND NOT HAVE TO USE A TRANSFORMER? THE RADIO IS IN GREAT SHAPE, AND WOULD REALLY BE GOOD IF YOU COULD USE 100. THANKS
The whole idea is a fairly big conversion. Some may say that it would depreciate the value of the set. Still, when done it will allow you to use the radio on AC with no hassle. For me, I have no real sentimental thing for vibrator radios except for in cars, and though I like to keep things all original, I would rather have a radio that works on AC than one that requires a large battery or converter. The vibrator can detract from the listening experience, too. Still, if there was room inside the radio and you used a solid state vibrator, you could place a small power supply inside the radio. This would allow the radio to be original. Solid state vibrators do not make a mechanical noise, and they don't generate radio frequency noises, either. They are exceptionally reliable.
If you do not need the chassis, you may use parts from it. Otherwise parts are readily available elsewhere, such as the socket and the electrolytics and the ballast resistor.
