Atwater Kent 67 Tube 71a looking for 5 pin replace tube
2/20/2005 2:10:07 PMJoe Prinzinger
I finally got my DC power supply done and went to hook up my Atwater Kent model 67 (battery). I had aquired all the tubes it needed. As I was putting in the new tubes I got to the 2A tubes in the back which are suposse to be cx-371A, UX-171A, or a 71A tubes. These fore mention tubes are four pin tubes. However, the tube sockets where they are to fit are 5 pin sockets. It looks like they were orginally wired in at the factory. What tube do I need to go into these five tube sockets? Don't you just hate it when the radio you are working on is somehow different than it schematic? Thanks!!!!!!!!!!
2/21/2005 12:24:49 PMNorm Leal
Hi Joe
Atwater Kent Model 67 uses 3 - #22, 2 - #12A and 2 -#71A tubes. These are all 4 pin.
What voltage is wired to filament of your 5 pin sockets. There wasn't very many 5 pin, battery, output tubes available when this radio was made. #49 and #33 are 5 pin tubes both with 2 volt filaments.
:I finally got my DC power supply done and went to hook up my Atwater Kent model 67 (battery). I had aquired all the tubes it needed. As I was putting in the new tubes I got to the 2A tubes in the back which are suposse to be cx-371A, UX-171A, or a 71A tubes. These fore mention tubes are four pin tubes. However, the tube sockets where they are to fit are 5 pin sockets. It looks like they were orginally wired in at the factory. What tube do I need to go into these five tube sockets? Don't you just hate it when the radio you are working on is somehow different than it schematic? Thanks!!!!!!!!!!
2/21/2005 5:50:13 PMJoe Prinzinger
Hi Norm!!!
According to the schematic it is 5 volts. However, the schematic does not show a five pin socket. I guess I need to attach it to the power supply and see what voltage goes to the filametes of these two tubes. If it is two volts, I have two 33 tubes that I will try.
Thanks for the advise.
Joe :>)
:Hi Joe
: Atwater Kent Model 67 uses 3 - #22, 2 - #12A and 2 -#71A tubes. These are all 4 pin.
: What voltage is wired to filament of your 5 pin sockets. There wasn't very many 5 pin, battery, output tubes available when this radio was made. #49 and #33 are 5 pin tubes both with 2 volt filaments.
::I finally got my DC power supply done and went to hook up my Atwater Kent model 67 (battery). I had aquired all the tubes it needed. As I was putting in the new tubes I got to the 2A tubes in the back which are suposse to be cx-371A, UX-171A, or a 71A tubes. These fore mention tubes are four pin tubes. However, the tube sockets where they are to fit are 5 pin sockets. It looks like they were orginally wired in at the factory. What tube do I need to go into these five tube sockets? Don't you just hate it when the radio you are working on is somehow different than it schematic? Thanks!!!!!!!!!!
2/21/2005 5:50:15 PMJoe Prinzinger
Hi Norm!!!
Joe :>)
:Hi Joe
