The second Item - there are two wires attached to the right side of the chassis that go nowhere..seemingly related to the third tube coil on the right side of the chassis. There is a switch on that side of the cabinet that has no wires going to it that is marked 'local' and 'distant'. The wires may go there, but I can't tell from the schematic I have downloaded from this site. Also, I don't want to 'try' to put these on the switch w/o knowing if they should go there as they may blow other
components.
The cabinet is in pretty good original shape and i'd like to hear it play. So, what the radiola needs is: what are the three other tubes besides the UX245 and UX 280 and where sre those wires supposed to be connected?
Thanks, Steve
Your radio is the AC version, since it does have a #80 rectifier tube. You should also see a power transformer. A single #45 tube is used in the output, as this is all that is needed to obtain adequate audio power with the high voltage power system used in this radio. In the RF section, (3) #24 tubes are used. These tubes employ indirectly heated cathodes, which is usually necessary in RF circuits of AC radios.
As for your two wires in question, it is best to state what they connect to. This will allow others to determine their function for you. If one connects to the end of the antenna coil and the other connects to a .00025 MFD condenser that connects to what looks like the chassis in the circuit diagram (should at least go to the ground terminal on your radio), then these are indeed the wires for the local/distant switch.
Once you obtain all of the appropriate tubes for your radio, don't fire it up just yet. Be sure to test ALL condensers for any trace of leakage. Electrolytics, if any (I didn't check), should have no more than 10 meg leakage (none is optimum), and when any value above 1 MFD is tested on your meter, a good electrolytic will cause the meter to swing ALL THE WAY to zero and then fall slowly back down to 10 meg or higher. Weak ones will not cause as much of a deflection. For now keep reading, but later on, after you have gotten your set to run, you should check the electrolytics again after perhaps an hour of operation. At this point they should have rejuvenated and should have no leakage. If they still have 10 meg leakage or there-abouts, they are questionable, and replacements would not be a bad idea.
All other condensers should have NO LEAKAGE. Any value above .001 MFD will cause a very small deflection of the needle (barely noticeable in many cases). Any value below .001 MFD will not likely cause a noticeable deflection. Should the needle be deflected in any case, it must fall back to EXACTLY where it started. Any leakage, even in the millions of ohms, will cause the set to perform at less than optimum. Check condensers by disconnecting them from the circuit. Check your resistors for proper values, too, and disconnect them as well during the test. Do not touch both meter leads with your hands or you will throw off readings.
Good luck!
:There are tons of great places to acquire tubes. The two that I go to the most are www.tubesandmore.com (a supplier of just about everything you'll need for your radio including new cloth wire), and eBay. You can find all of the tubes for your radio on eBay. www.tubesandmore.com doesn't always allow you to select brands, though RCA is the most popular, so your chances of getting RCA tubes is high. On eBay you can see what tubes you are getting (usually), though in your case they are usually used. Try to go for tubes that are tested. www.tubesandmore.com sells both new and used tubes as well, and their catologue is easier to read than their web site (it isn't like going through a maze and hitting dead ends all the time...you just page through and look at all that you want). Their web site has more updates, though.
:Thomas
:Thomas
To go into a little detail, another example of a connection not needed is where a manufacturer wires a variable tone control. One end of the potentiometer is connected to a condenser that goes to the audio circuit. The center wiper terminal is connected to ground. The other end terminal is also connected to ground. There is no real purpose for this. When the tone control is turned to maximum resistance, the wiper will be touching the high end of the resistance element and the external connection will also connect to this end of the element. Redundant, but done just the same.
If I come up with any other theories on the switch wiring, I'll let you know. Perhaps someone else will come up with an idea, too, but as far as I can see, the switch should be wired as I stated above.
Perhaps I can do something for you in the future!
Steve
:Well, if you know that the wires you see are indeed the local/distant wires, then you may connect these to the switch in any way you see fit. I will have to think about why all three terminals were used. The switch may have simply been a two position switch at hand at the factory, which was also used for other purposes. The ideal way to wire the switch would be to find out which terminals are closed when the switch is thrown to the local positon. The center terminal is likely connected to the moving contact. Connect the ground wire to this terminal and to the terminal that is OPEN. Then connect the antenna coil wire to the terminal that is closed, or connected to the center terminal. Connecting the ground wire to the open terminal has no real purpose other than to perhaps provide a little bit of shielding. It is not necessary as far as I can see. Sometimes manufacturers made connections like this, though, which may or may not have improved set performance.
:To go into a little detail, another example of a connection not needed is where a manufacturer wires a variable tone control. One end of the potentiometer is connected to a condenser that goes to the audio circuit. The center wiper terminal is connected to ground. The other end terminal is also connected to ground. There is no real purpose for this. When the tone control is turned to maximum resistance, the wiper will be touching the high end of the resistance element and the external connection will also connect to this end of the element. Redundant, but done just the same.
:If I come up with any other theories on the switch wiring, I'll let you know. Perhaps someone else will come up with an idea, too, but as far as I can see, the switch should be wired as I stated above.
:Thomas
The question today is: I was looking at the other two tubes and saw the UX 245 there is actually labelled UX 345 (Cunningham brand). Is this okay? Or will it not function or cause damage?
Again, Steve
:Nope. I just give advice. I don't take anthing in return.
More modern tube numbers dump the whole manufacturer concept and simply label the number itself, such as 2A3, 6A7, 6D6. Then with octals, you'll find shell designation like no designation for metal, G for large glass, and GT for tubular glass. Etc.....
:Thank you, Thomas..I orderd the three tubes I needed this morning and just have to figure out the wiring to the switch (hopefully) .
:The question today is: I was looking at the other two tubes and saw the UX 245 there is actually labelled UX 345 (Cunningham brand). Is this okay? Or will it not function or cause damage?
:Again, Steve
::Nope. I just give advice. I don't take anthing in return.
I'm bringing back to life a Radiola 46 at this time. Your tube questions were already answered. For the local/distant wires, looking towards the back of the switch, yellow-right black-left on the bottom, and green for the single top terminal. There's another apparently yellow wire soldered to the bottom of the raceway that the other wires run in, if your raceway is still there.
Regarding the filter caps, they are all wax paper, located in the box diagnal from the 80 and 45 tubes. The output choke is also in this box. Something of a PITA to replace and restuff with all the wires, but doable, and I'd suggest you do.
Also look for problems in the power resistor banks. There are two banks of big ceramic resistors. Out of nine total sections, 8 of mine were burned open. Rather than try to cram in all the new ceramics, I ran leads out of the chassis to a seperate board. I'll mount that board vertically when I put it all back together for air flow.
I've got service information if you need it, or you can get your own here:
http://www.radiolaguy.com/manuals.htm
Good luck!
Richard
RichardD "at" fool.com
:So, what the radiola needs is: what are the three other tubes besides the UX245 and UX 280 and where sre those wires supposed to be connected?
:Thanks, Steve
