You can use a 470 ohm @ 2 watt carbon resistor. This resistor is used in series with cathode of a 6F6 output tube. This resistor dissipates around 1 watt.
Look for 470 ohms rather than 450. 450 is no longer a standard value.
:I need to replace a 450 Ohm 1 watt flexible resistor (R-11) in a GE model A-53 tombstone. I have been unable to find a source for flexible resistors. Can I substitute it a 470 Ohm 1 watt carbon composition resistor? Will this affect the performance of the radio?
Thomas:
Thanks for the responce.
Leon
i have replaced a few of these most recently in a all american mohawk but i never knew they had a name i just thought they were an old type of wire wound res. i was wondering since as you say res. are no longer available in the exact ohm rating, so what is the tolerance some say 20%others say 10% is it better to go a little higher or a little lower.i wounld't think its too critical as i have seen them run fine when most of the res. are way out of tolerence. butch
:Thomas:
:Thanks for the responce.
:Leon
:i have replaced a few of these most recently in a all american mohawk but i never knew they had a name i just thought they were an old type of wire wound res. i was wondering since as you say res. are no longer available in the exact ohm rating, so what is the tolerance some say 20%others say 10% is it better to go a little higher or a little lower.i wounld't think its too critical as i have seen them run fine when most of the res. are way out of tolerence. butch
