Philco alignment procedure
2/16/2005 9:47:01 PMDan
I am haveing problems aligning a Philco receiver model number 46-1209 code 121. I printed the schematic from this site and it did not contain an alignment procedure for this model
2/17/2005 9:15:12 AMJohn McPherson
I assume you viewed the file for the first page and printed that page via the web browser, or you did a "right click" Save image as.... Or Did you download the PDF file here for your set? If so, the page is Philco page 15-34 for the alignment instructions for your set, and it does appear that it should be a part of the full PDF.
:I am haveing problems aligning a Philco receiver model number 46-1209 code 121. I printed the schematic from this site and it did not contain an alignment procedure for this model
2/17/2005 10:33:31 AMPoston Drake
Hi Dan,
There is a problem with NostalgiaAir listing for the model 46-1209. Rider page 15-34 is the one you need (it contains alignment and pushbutton adjustment instructions) but although this page is listed it does not show up on the scans (they jump from 15-33 to 15-35). Maybe if you contact Richard Lancaster he can correct this?
In the meantime if you have a simple alignment question ask it here, or if you need the complete instructions email me and I can send them to you.
Poston
