:Hi
:I need a schematic for a RCA tabletop radio. The model number on the chassis is RC1001B. This model number is not in the model nnumber. Thanks
::Hi John,
::An RCA number with an "RC-" prefix would be the chassis number, not the model number. But a chassis number should be sufficient to find a listing in either Rider or SAMS Photofacts. However, I cannot find the "RC-1001" listed anywhere. You might want to double-check that number?
::Poston
::Yeah, it is the chassis number. And, I've checked it 100 times. the one that is simular is RC 1050, but the tube configuration is not right. The problem I am having is a 1200 ohm resistor is heating up across the power output tube. I have checked the audio transformer, and it ohms out to 250 like the RC 1050 calls for. I get a hum out of the speaker, but then, the resistor heats up (smoking). Any ideas?
:::Hi
:::I need a schematic for a RCA tabletop radio. The model number on the chassis is RC1001B. This model number is not in the model nnumber. Thanks
Gentlemen,
My Beitman Supreme Publications index shows a diagram in the 1941 manual on page 121 for an RCA RC1001B (12X and 12X2). I believe it was mentioned that the 1200 ohm resistor trys to burn up. The schematic shows a 1200 ohm resistor (R9) in the power supply filter circuit between the input filter cap (30MFD) and output filter cap (50MFD). Have you replaced the power supply filter caps?
Did a little research on this site using RCA 12X. Try looking at http://www.nostalgiaair.org/PagesByModel/745/M0014745.pdf.
The resistor in question is the filter resistor (1200 ohms). Use a 1 watt resistor for replacement. Also replace the electrolytic filter capacitors (30 mfd input, 50 mfd output) if you have not done so already. A leaky or shorted output filter capacitor can cause the filter resistor to burn up. If you continue to have trouble after replacing the filter capacitors, then the B+ plate circuit is drawing too much current (most likely due to leaky paper caps or a short somewhere in this circuit.)
Poston
::The tubes are as follows: 12SA7 1st det.&Osc.,12SK7 IF, 12SQ7 2nd Det.,AF,and AVC, 50L6GT Output, 35Z5 Rectifier. Thanks
:Your Info was great. I found the schematic and the caps that were in the radio was not the correct size. Someone had put 2 16mf in for the 50 and 30. I put the correct value in and no more problems. Thanks for your help.
