Crosley 167? schematic help
2/9/2005 4:56:52 PMDavid G
HELP! I have a Crosley model 167 that I am trying to restore, but the chassis inside the case doesn't match the schematic for a 167. Can anyone help me identify the correct model for this chassis? The 167 scematic says that the chassis should have tube sockets numbered 37, 38, 38 & 57. The chassis that I have has tube sockets numbered 42, 57, 58, 58 & 80. 5 tubes, NOT 4! I can provide pictures if it will help. Thanks in advance to ANYONE who can help.
2/9/2005 5:49:38 PMJohn McPherson
If the Rider page is indicated as Crosley page 4-9,
The numbers that you refer to are just reference numbers to the part numbers.
The output is a 42, the rectifier is an 80, (40 is actually a voltage amplifier triode), the sockets should be marked, and based on what I see, you should have 2 type 58's and 1 type 57 for the remainder of the tube complement. The 57 being the "37" and the 58 being the "38".
Your chassis is correct, the schematic was just drawn strange.
:HELP! I have a Crosley model 167 that I am trying to restore, but the chassis inside the case doesn't match the schematic for a 167. Can anyone help me identify the correct model for this chassis? The 167 scematic says that the chassis should have tube sockets numbered 37, 38, 38 & 57. The chassis that I have has tube sockets numbered 42, 57, 58, 58 & 80. 5 tubes, NOT 4! I can provide pictures if it will help. Thanks in advance to ANYONE who can help.
2/9/2005 10:29:45 PMDavid G
John,
Thanks. I completely missed that. I had completely redrawn the schematic, replacing ref. #s with real values (to try to get it to make sense) & got those wrong + I didn't see the 80 socket drawn next to the transformer. I am having real trouble with this since it appears that someone made repairs to the unit in the 50s & now NONE of the capacitors that I can read match any of the values in the schematic. I will try to trace it out again. Thanks again for pointing out my oversite.
:Hi,
:If the Rider page is indicated as Crosley page 4-9,
:The numbers that you refer to are just reference numbers to the part numbers.
:The output is a 42, the rectifier is an 80, (40 is actually a voltage amplifier triode), the sockets should be marked, and based on what I see, you should have 2 type 58's and 1 type 57 for the remainder of the tube complement. The 57 being the "37" and the 58 being the "38".
:Your chassis is correct, the schematic was just drawn strange.
::HELP! I have a Crosley model 167 that I am trying to restore, but the chassis inside the case doesn't match the schematic for a 167. Can anyone help me identify the correct model for this chassis? The 167 scematic says that the chassis should have tube sockets numbered 37, 38, 38 & 57. The chassis that I have has tube sockets numbered 42, 57, 58, 58 & 80. 5 tubes, NOT 4! I can provide pictures if it will help. Thanks in advance to ANYONE who can help.
2/10/2005 1:08:06 PMThomas Dermody
I find it difficult, too, to read schematics that do not have the tubes circled. You have to adjust your eyes, almost.
T.D.
