It is easiest if you know the voltages of the secondary, because AES does carry quite a number of them, as does "Playthings of the Past". You could also try "The Radio Junkyard" for an old stock used replacement. I will take a look in some of my references to see if it is listed with a Stancor or Thordarson replacement number.
:Hello:
: I have a Stewart-Warner radio-phono-recorder with a bad power transformer. The model number of the radio-phono-recorder is model:11-6T1.I believe the part number is 160172.Where should I start in attempting to find a replacement?
