I tried replacing the disk capacitors around the 1U5 tube, but the problem is still there. The 1U5 plate voltage is only 15 volts, half of what it should be. I even tried a different 1U5 without success.
The original selenium rectifier is still in place; I'm only getting 95 Volts instead of 115.
Thanks!
With disc condensers, leakage is not usually as much of a problem. With my older portables, which use paper condensers, a problem I frequently have is that the volume will die down after 15 or 20 minutes of operation, and will become somewhat distorted. Leakage even in the millions of ohms through the audio bypass condensers will cause this problem. Check all audio bypass condensers, even at the volume control. Check tone condensers as well. Using your most sensitive resistance meter setting, with the condenser disconnected, if the needle swings up at all (a hare's breath or less), it should fall back to exactly where it started. Anything less in these extremely high impedance circuits will cause trouble. Be sure that when you test a condenser that you disconnect one of its two leads. Do not touch both of the meter leads with your fingers at the same time or the conductivity of your fingers will throw off the reading.
