Anyway, the positive side of electrolytics always goes to the cathode of the rectifier or any resistors leading to the cathode of the rectifier. The negative side goes to the center tap of the transformer, or any resistors that lead to the center tap of the transformer.
hi thomas and thanks it looks like i do have eletrolytics reversed as i have the center tap of the plate voltage going to the + end of the electrolytics funny i didn't smoke them.i'll try again i thought this might be the prob. but it just did'nt look right the other way.thanks again :butch
hi again set is up and running changing cap. polarity worked now the only problem is low volume i know the seperate filament xformer i'm using is to small it's only 4 amp i need a eight or ten amp unless i could use the six volt tap on the replacement xformer but i can't see how i better just order one from aes thanks for all your help .butch
When reading your circuit diagram, zoom in on all connections that you do not clearly see. A dot means that there is a connection. If two wires cross and there is no dot, then they are not connected. The dots are really small on this particular diagram, which is why I say you should be careful.
Of course be sure that your set is aligned properly, as this may have something to do with its low volume. Be sure, too, that no condensers are leaky, even in the millions of ohms--that is, if you haven't already replaced them. .....drifted resistors, etc.
Good luck,
http://www.nostalgiaair.org/PagesByModel/842/M0009842.pdf
A note on what I said about biasing resistors for the output section: with a filamentary type tube that uses alternating current for the filament, B current must be applied carefully to the filament at a central location. This is done by using a center tap on the filament transformer. If the current was applied to one side of the winding or the other, the alternating current 2.5 volts would constantly be added to and subtracted from the B current, which would introduce hum.
T.D.
hi thomas i am just starting to recap tonite and i have only checked the tolerence on a few res. but i will get this all done the plate current is fine i am using a seperate filament xformer as the power xformer i had has a six v. filament winding instead of a 2.5 v. but the filament xformer i have is only 3 amps the filaments draw over 7 amps so with this xformer you can barly see the filaments glow i ordered a 10 amp one this afternoon i don't know if this is the problem or not but i couldn't be getting much emission but i'll go through it all while i'm waiting for the parts i'm just happy its working at all its been sitting here for almost 2 years it worked good when i first had it then the power xformer blew and i am just getting around to repairing it. i had hoped a power xformer with a 2.5 v. winding would come along but they seem as scarce as hens teeth i know you can buy them but they are pretty pricey and the ones i've seen wouldn't fit this set well whereas the one i'm using bolted right in. butch
I purchased another version of this transformer many years ago when I was 15. It had a 325 volt high voltage and a smaller 2.5 volt winding with center tap. I forgot what the amperage was. This was used for powering an 80, 2A3, and a 57. It worked very well and still works very well. The only thing I did not like about this transformer is how it has always gotten quite warm. There have been transformers made in old radios, though, that get very warm, too, so I guess that's not so bad. Many radios I have, though, have transformers that do not get above 100 degrees. This transformer should work alright for what you need, though. Mine seems to have lasted a long time--10 years, at least.
P-T143
2004 Catalog
page 38
TRANSFORMER, POWER, HAMMOND, 350-0-350 V, 70-90 mA
Custom manufactured to replace most 6 and 7 tube sets of the early 1930's. Supplied with vertical mounting shells. Leads come out one side to enable horizontal mounting. Feet for vertical mounting can be cut off to enable horizontal mounting. Mounting centers in parentheses apply to horizontal mounting. Provides a seperate filament winding for audio output stages but both 2.5 volt windings can be paralleled for the combined current rating.
Specifications
Rating: 350-0-350 V, 70 or 90 mA (if 5 V winding is used with 2 A rectifier)
Windings: 5 V, 3 A; 2.5 V, 7.5 A; 2.5 VCT, 3.5 A
Mounting Centers: 2.3125" x 2.5" (2.25" x 3.125" for horizontal)
Weight: 4.6 lbs.
$59.95
Qty
hi thomas i saw that transformer but wasn't sure it would fit i'll try the the filament xformer first as it gives me a little more room by mounting in a different spot than the main xformer then when that doesn't work i'll buy the other one making sure i spend twice as much money as i needed to this is my usual procedure .thanks .butch
Good luck!
