I went to a Howard W, Sam's Photofact website (http://www.samswebsite.com/). The Sam's Photofact folder is 310 and section 10. Instead of purchasing it there for $20.00 plus S & H perhaps someone else here has a copy and will respond. Get the original Sear's part numbers for both items in the Photofact for a reference.
Bob WB5YYX
:I need to find both a volume knob and a motor for this model of console and i'm having a hard time finding any info on these anywhere. if anyone knows where i can get parts, please let me know!
The whole idea in parts research is to get the original manufacurer's part number for cross referencing and a description. This way you are covered if there is no direct cross reference. In your case however I am sure you want it to look as original as you can make it. I was in the retail electronic parts business for 20 years. Things like knobs and other such parts are normally OEM (Original Equipment Manufacturer). Electronic components such as resistors, capacitors, etc. are just general replacements. Manufacturers today perhaps produce OEM parts for 5-7 years if you are lucky. They really want you to do a new purchase. That's where they make the most cash flow and profit in one lump sum. Parts inventory is more expensive for them.
Bob WB5YYX
If you can pull the turntable platter up, there will likely be a name like "VM" and some other numbers, if there is no name elsewhere on the turntable mechanism. There might be a paper tag attached to the bottom side of the turntable itself too. Short of that, a picture of the turntable where the edges of the mechanism fill the frame, along with the same size image without the turntable platter in place. I might have something there too.
If you do send jpegs, try to scale them down in file size so they do not take forever to download.
Normally I do not post my email, because of web spiders and the spam they create, just change the "AT" and "DOT" to the actual characters. Otherwise if you have a webpage where you might be able to post those picture is also another solution too.
