A 6F6 will get very hot, especially metal. It will burn your hand. Measure voltage between pin #5 and #8 on this tube. If pin #5 is negative 20 volts or so temperature of your 6F6 is probably normal.
Touch the top cap on your 6F5 tube. This should cause hum from the speaker if audio section is ok.
A schematic can be found here if you don't already have one:
http://www.nostalgiaair.org/PagesByModel/458/M0015458.pdf
Measure plate and screen voltage on each tube. They should be positive.
:I am restoring a 1934 model C8-15 and have replaced 10 capacitors but can only get loud static noise though the speaker. Tubes are all good and has new 6F6 output tube. This tube gets sizzling hot.
:Any thoughts on possible problem please let me know. Apreciate your help.
