: Second item is a small wooden box about 4 X 4 X 6-inches with the following thumb screw type terminals mounted on the front face of the box: left vertical-two terminals , each labeled "INT", In center front is a Large round insulator type material with outside threads like to allow a cap to be threaded over the terminal, it is about 1-inch diameter with thumb-screw terminal, to the right of this is another terminal marked "GND" on the right vertical side, two terminals- top is "Neg", bottom is "Pos". On the top left of the box is a brass strip with an insulated knob, spring-loaded open (looks like a miniature CW key) marked "start", to the right of this (key) is a rotary type off-on switch. Single lever moves horizontally to and from a contact.
: The unit was made by the Atwater Kent Mfg Co., Phila., PA and identified as "System-K. Pat. in 1904,10,11 and 1912.
: Whe applying a small potential to the pos and neg terminals I can get a real hot spark across the center terminal and GND terminal when I tap the start key. Anyone recognize these devices?
: : Second item is a small wooden box about 4 X 4 X 6-inches with the following thumb screw type terminals mounted on the front face of the box: left vertical-two terminals , each labeled "INT", In center front is a Large round insulator type material with outside threads like to allow a cap to be threaded over the terminal, it is about 1-inch diameter with thumb-screw terminal, to the right of this is another terminal marked "GND" on the right vertical side, two terminals- top is "Neg", bottom is "Pos". On the top left of the box is a brass strip with an insulated knob, spring-loaded open (looks like a miniature CW key) marked "start", to the right of this (key) is a rotary type off-on switch. Single lever moves horizontally to and from a contact.
: : The unit was made by the Atwater Kent Mfg Co., Phila., PA and identified as "System-K. Pat. in 1904,10,11 and 1912.
: : Whe applying a small potential to the pos and neg terminals I can get a real hot spark across the center terminal and GND terminal when I tap the start key. Anyone recognize these devices?
PRO – VITA LTD.
PRODUCTION COMPANY AND SERVICE
EXPORT – IMPORT
TEL + 381 63 793477 & Fax + 381 11 3972121
TEL + 9641 4236169 & ICQ : 6 2 4 4 01 4 4
E.mail : L u t f i @ i n f s k y . n e t
Dragice Koncar 14/17 , Belgrad - YU
Dear sir , Our company is a specialized company for trade and engineering service . our profile to working with Marines generators and industrial power generators and portable generators . in view of demand from our partners witch is located in Syria , Jordanian , Lebanon , Iraq we need from your side the completely information about your production program with completely catalog and also with your export price on destination CIF-Aqabah (JORDAN) if it's possible.Anyway this documents should be sanded by post mail on our address in Yugoslavia .
Thank you for your kind attention to our company and look forward to hearing from you soon .
Best regards,
Eng. Lutfi Sarmad
