can you help me identify this radio ?
12/21/2004 3:44:57 AMPonmarcn
it is an air king model between 30 and 40ies (i believe) vertical in wood. with 25z5, 43, 75, 78, 6k7, 6a7 tubes
I bought this radio on e-bay and i wish to restore it so i need much more info that is possible most of all model(schematics, etc)
the radio can be viewed following this link
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&rd=1&item=7118518148&ssPageName=STRK:MEWN:IT
thanks for help
Marco
12/24/2004 2:33:07 PMNick
:it is an air king model between 30 and 40ies (i believe) vertical in wood. with 25z5, 43, 75, 78, 6k7, 6a7 tubes
:I bought this radio on e-bay and i wish to restore it so i need much more info that is possible most of all model(schematics, etc)
:the radio can be viewed following this link
:http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&rd=1&item=7118518148&ssPageName=STRK:MEWN:IT
Nice looking radio! I have had luck going to the 'Resources' section of this web site and just opening up each model (Air King) schematic and looking at the tube lineup and other features which are obvious on the chassis (component locations). It is time consuming but your odds of finding it are good. Nick
:thanks for help
:Marco
12/26/2004 7:37:33 AMponmarcn
::it is an air king model between 30 and 40ies (i believe) vertical in wood. with 25z5, 43, 75, 78, 6k7, 6a7 tubes
::I bought this radio on e-bay and i wish to restore it so i need much more info that is possible most of all model(schematics, etc)
::the radio can be viewed following this link
::http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&rd=1&item=7118518148&ssPageName=STRK:MEWN:IT
:Nice looking radio! I have had luck going to the 'Resources' section of this web site and just opening up each model (Air King) schematic and looking at the tube lineup and other features which are obvious on the chassis (component locations). It is time consuming but your odds of finding it are good. Nick
::thanks for help
::Marco
12/26/2004 7:40:56 AMponmarcn
i tryed already , no results, some are quite close for lamps, but no match mostly one lamp less !!
::thanks for help
::Marco
12/26/2004 12:56:23 PMNorm Leal
Hi
Try model Knave:
http://www.nostalgiaair.org/PagesByModel/465/M0000465.pdf
Something is wrong with your tube listing? Both 78 and 6K7 are the same type tube with different bases. Not likely a manufacturer would use both in one radio. Does it look like the 6K7 socket was installed later?
The schematic shows 6D6 tubes. These can be replaced by 78 (interchangeable) or 6K7 if a socket is changed.
:i tryed already , no results, some are quite close for lamps, but no match mostly one lamp less !!
:::it is an air king model between 30 and 40ies (i believe) vertical in wood. with 25z5, 43, 75, 78, 6k7, 6a7 tubes
:::I bought this radio on e-bay and i wish to restore it so i need much more info that is possible most of all model(schematics, etc)
:::the radio can be viewed following this link
:::http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&rd=1&item=7118518148&ssPageName=STRK:MEWN:IT
::Nice looking radio! I have had luck going to the 'Resources' section of this web site and just opening up each model (Air King) schematic and looking at the tube lineup and other features which are obvious on the chassis (component locations). It is time consuming but your odds of finding it are good. Nick
:::thanks for help
:::Marco
