high quality hand magnifier - free
3/29/1998 4:07:05 AMDamian Appert
Sometimes it is nearly impossible to read the tiny
markings on electronic components. The lens assembly on
those old discarded 8mm movie projectors make very good
quality, high magnification magnifiers. You look thru
them backwards, ie the outer lens goes next to your
eye and you get a huge image when the other end is held
about one centimeter from the component markings.
2/17/2000 7:33:01 PMG. JACOBSON
: Sometimes it is nearly impossible to read the tiny
: markings on electronic components. The lens assembly on
: those old discarded 8mm movie projectors make very good
: quality, high magnification magnifiers. You look thru
: them backwards, ie the outer lens goes next to your
: eye and you get a huge image when the other end is held
: about one centimeter from the component markings.
8/15/2000 10:13:16 PMLerzan Erkilic
10/13/2000 6:06:57 AMAngel Angelov
