AK35 RF coils
12/7/2004 11:24:48 PMbill noro
Does anyone know the gage of wire and no. of turns for the rf coils?
12/8/2004 2:35:49 PMNorm Leal
Hi Bill
I measured the main winding as having wire @ .008. This turns out to be 32 ga. I have seldon found the main winding to be open. Usually mice damage the smaller, coupling winding.
A model 35 has 3 RF coils. Check one of the other coils to determine number of turns on the main winding. Use 10 turns on the coupling winding although each coil has a different number of turns here.
If you don't have any of the coils figure 125 turns for the main winding. This will give 1" of #32 wire. Exact number of turns isn't critical but all 3 coils should be the same here. The main winding determines frequency range of tuning.
:Does anyone know the gage of wire and no. of turns for the rf coils?
12/8/2004 11:28:15 PMnorm leal
Hi Norm.
Thanks for the info. All three coils are there but it looks like extreme moisture has gotten to the set. All 3 RF coil (primaries) are open, along with the antenna choke coil, and both audio transformers. A lot of work to rebuild. The secondaries are OK. Thanks again,
Bill
:Hi Bill
: I measured the main winding as having wire @ .008. This turns out to be 32 ga. I have seldon found the main winding to be open. Usually mice damage the smaller, coupling winding.
: A model 35 has 3 RF coils. Check one of the other coils to determine number of turns on the main winding. Use 10 turns on the coupling winding although each coil has a different number of turns here.
: If you don't have any of the coils figure 125 turns for the main winding. This will give 1" of #32 wire. Exact number of turns isn't critical but all 3 coils should be the same here. The main winding determines frequency range of tuning.
::Does anyone know the gage of wire and no. of turns for the rf coils?
