Ident old Philco Radio
3/27/1998 10:31:02 PMNorvin F.
Need a schematic and age info on a Philco radio, it's
in a bakelite case it uses five tubes 7A8, 7C7, 7C6,
50L6GT, 35Z3. It currently is receiving out of band,
its AM only and a table top radio. On the front it says
Philco and Transitone under the philco.
Thanks in advance!
3/29/1998 12:58:51 PMFco. Javier Urroz
: Need a schematic and age info on a Philco radio, it's
: in a bakelite case it uses five tubes 7A8, 7C7, 7C6,
: 50L6GT, 35Z3. It currently is receiving out of band,
: its AM only and a table top radio. On the front it says
: Philco and Transitone under the philco.
: Thanks in advance!
Hi Norvin.
The reference "Transitone" do not help too much.
I have had a look of "The collector's guide to Antique Radios ( Third edition )" By Martin & Sue Bunis and I see that since 1939 to 1948, Philco manufactured receivers with that reference.
I have also consulted the great book on Philco writen by Ron Ramirez "Philco radio 1928-1942" .There are lots of pictures and information on chassis employed, and tubes, but unfortunately, I can' find any chassis with the exact five tubes you mention. There are several similar with a tube 7B7 instead of 7C7(The rest of tubes remain the same ):
Models 42-PT2,42-PT4,42-PT7,PT-30,PT 49, PT-42, PT-44.
( I have schematics of some of them)
With six tubes ( the five you mention and one 7B7 ) is the model 42-321 and 42-PT10 ( I also have schematic)
( and of course I will e-mail it to you free !)
Could you e-mail me giving more details of your receiver ( color, number of knobs, dial position and shape)? I wish I could help you.
I recommend you to visit these two specific internet sites about Philco:
http://members.aol.com/philcodata/pdatindx.htm
www.chevytrucks.org/mrphilco/mrphilco.html
This last site is the web page of Ron Ramirez (above mentioned ). Is an expert on Philco.
Regards.
Javier ( I'm writing from Pamplona, Spain)
5/11/1998 3:06:06 PMsusan shaw
: : Need a schematic and age info on a Philco radio, it's
: : in a bakelite case it uses five tubes 7A8, 7C7, 7C6,
: : 50L6GT, 35Z3. It currently is receiving out of band,
: : its AM only and a table top radio. On the front it says
: : Philco and Transitone under the philco.
: : Thanks in advance!
: Hi Norvin.
: The reference "Transitone" do not help too much.
: I have had a look of "The collector's guide to Antique Radios ( Third edition )" By Martin & Sue Bunis and I see that since 1939 to 1948, Philco manufactured receivers with that reference.
: I have also consulted the great book on Philco writen by Ron Ramirez "Philco radio 1928-1942" .There are lots of pictures and information on chassis employed, and tubes, but unfortunately, I can' find any chassis with the exact five tubes you mention. There are several similar with a tube 7B7 instead of 7C7(The rest of tubes remain the same ):
: Models 42-PT2,42-PT4,42-PT7,PT-30,PT 49, PT-42, PT-44.
: ( I have schematics of some of them)
: With six tubes ( the five you mention and one 7B7 ) is the model 42-321 and 42-PT10 ( I also have schematic)
: ( and of course I will e-mail it to you free !)
: Could you e-mail me giving more details of your receiver ( color, number of knobs, dial position and shape)? I wish I could help you.
: I recommend you to visit these two specific internet sites about Philco:
: http://members.aol.com/philcodata/pdatindx.htm
: www.chevytrucks.org/mrphilco/mrphilco.html
: This last site is the web page of Ron Ramirez (above mentioned ). Is an expert on Philco.
: Regards.
: Javier ( I'm writing from Pamplona, Spain)
This is my first attempt to send a message on the Internet so please bear with me if I do actually manage to reach someone.
I,too,have a Philco radio just inherited from my Mother. I can't identify it either and the Philco Book by Ramirez is not in our local bookstore.
I'm not sure what I should relate so I will give a sketchy description of the cabinet first.
Brown wood (walnut?) with two thin light gold stripes (inlay?)running vertically across the top of the cabinet and then down the face in the speaker section. It is about 15x10x8 inches and weighs a ton.
Facing the front of the cabinet the speaker section is on the left and there are 4 vents backed by the speaker cloth. The vents are rectangular about 4" high by 1" wide, however all the corners of the rectangles have been rounded.
On the right hand side are 3 knobs, on/off - volume - tuning. Above the knobs is the tuning face,the upper part gold for the am bands, the bottom half dark for the shortwave bands.The word Philco is in this face.
In addition to the three knobs there is also a flip switch to the left of the on/off knob. This switch is used for the shortwave I think.
Looking at the back of the cabinet now. There is a abused metal plaque at the top that says Philco with a five digit number that I think starts 39- (Is this the model number?) Below this number are four other numbers with headings - the last one being
Watts 40. I believe that one of the other headings is the word cycles. I'm afraid to clean the plaque for fear of destroying some of the information. Any suggestions on what would work?
There are five tubes in a row sitting on a metal base. To the left of the tubes is a upright metal box which seems to have 2 wires coming from it. These 2 wires my Father attached to some old TV rabbit ears. On the right hand side at the bottom
is the regular wire and plug. This wire was folded up and pushed inside the cabinet. I took it out very carefully and found the cloth on the cord rotten at every fold and the wires were exposed. I plugged it in and it worked.
I listened to a cricket match on Radio Scotland. I then decided that the cord was a fire hazard so I wrapped it in electrical tape. I plugged the radio back in, turned it on and something went pop and it no longer works.
I'm in Montreal,Canada and would like to know what I have and where to go to get it fixed.
If you can help I would appreciate it. Thanks.
7/19/1998 6:20:11 PMGeorge Palermo
Need a schematic and year built for Philco 51A with square clock face, not cathedral. Tube line up 47, 24, 35, 24, 80. Thanks!
9/20/1999 5:27:58 PMEusebio Mejia Y
: Need a schematic and year built for Philco 41-714 is a short wave, not cathedral. Tube line is 7A7E, 7J7E, 7B7E, 6K6EC, 7Y4 Thanks!
4/17/1999 8:52:50 AMMarco Suarez
I information about a Philco radio model #47-1227
The radio is in great condition; the lights turn on and record player works, but I don't get any sound. I don't even know if it picks up any radio stations.
12/17/1999 11:05:30 PMMel
I would like information as to how to find orignal
parts for this radio. the cabinet has been refinished
and we would like to get buttons, knobs, tubes etc for
it.
Thank you,
Mel
10/22/2000 10:14:15 PMBrian Richards
I have a Model 42-321 Code 121. Do you have schematic ?
Also, do you have stencils for the "PHILCO" on the front ?
Thanks in advance for your response.
Brian
9/15/1998 6:24:28 PMWill Silva
: floor case,
: am only
11/23/1999 6:11:36 PMmike bagnall
I'm looking for a speaker for a philco model 90 radio.
Do you have any information on where I can get a replacement one.
10/3/2001 5:33:38 PMJ P BERENATO
: I'm looking for price on philco model 90 radio, floor model, not working. Condition fair.
5/24/2000 12:08:15 PMSheila Lutts
: : floor case,
: : am only
: : Thanks in advance! I have just purchased a Super Heterodyne Eleven Phone/Radio. Cabinet Designed by Norman Bel Geddes, Motor Black Flyer: The General Industries Company of Elyria OH. All this information is on the unit with a number of #061875 stamped on the chassie. Can you inform me of what model and any information on this unit? Tubes show type 24 ,24A,27.
8/27/2001 11:25:48 PMRobert Klem
: : : Need a schematic and age info on a Philco radio, it's
: : : floor case,
: : : am only
: : : Thanks in advance! I have just purchased a Super Heterodyne Eleven Phone/Radio. Cabinet Designed by Norman Bel Geddes, Motor Black Flyer: The General Industries Company of Elyria OH. All this information is on the unit with a number of #061875 stamped on the chassie. Can you inform me of what model and any information on this unit? Tubes show type 24 ,24A,27.
1/15/1999 2:18:13 AMjeff
I have a radio similar to yours except there's a shortwave
band and a broadcast band. It also has one more tube. (7D7)
Any idea where I can find replacements for them?
8/12/1999 1:49:45 AMHARRY WRIGHT
: I have a radio similar to yours except there's a shortwave
: band and a broadcast band. It also has one more tube. (7D7)
: Any idea where I can find replacements for them?
6/14/1999 11:14:15 PMMark Eckelkamp
I have a Philco Tube Radio with model 46-480
and i am haveing trouble finding the date it was made, and the estimated value,
if anybody can help or lead me to information
please help me!!
Mark
9/15/1999 7:14:52 PMdean
: I have a old Philco floor model 41-280. Does anyone know how old it is & how much it is worth. It used to play oversea channels. Thanks
4/29/2000 8:24:16 PMbrian simpson
: : I have a old Philco floor model 41-280 also. Does anyone know how old it is & how much it is worth. It used to play oversea channels. Thanks
5/22/2000 8:28:38 PMTimothy M. Ford
: : I have a old Philco floor model 41-280. Does anyone know how old it is & how much it is worth. It used to play oversea channels. Thanks
5-22-00
Mr Eckelkamp I have a Philco Radio 41-280. It was made in 1940. It has 8 tubes. It Is all there just like it came off the show room floor. It is in good shape. I do not know what it is worth. I'm trying to find out my self. I do not know of any web sights for this radio. E- mail me if you would like to know what I did to the radio and how my dad got it in the early 60's. kd5itm@yahoo.com Thanks Tim
12/10/1999 7:27:38 PMDon Weagel
I have a Philco telephone style radio.
Serial #: N O284101 Part #: 39-6131
It is approximately 10 inches long, 8 inches wide, and 6 inches high. On the top it has telephone looking dial with 10 finger holes and 10 corresponding tabs that allow a label to be added. The dial is a plastic material. The box itself is made of walnut.
If anyone has any information as to when this Philco was manufactured please let me know. Any information you have will be greatly appreaciated.
Thank you in advance, Donald Weagel
9/7/1999 12:19:53 AMsandif
Have an old Philco Model 42-395 radio.
Any information avail. on this antique?
Year made, value, etc. would be
appreciated. Know it has been in
family over 45 years for sure.
10/7/1999 11:24:44 AMgermán arrondo
: Have an old Philco Model 42-395 radio.
: Any information avail. on this antique?
: Year made, value, etc. would be
: appreciated. Know it has been in
: family over 45 years for sure.
3/13/2000 12:06:12 AMMichael Prosise
Your set was made in 1942, the last year of pre-WWII production. The first 2 didgits of a Philco model number are always the manufacturing date. A complete rundown on this set can be found in my book "Philco Radio: 1928-1942"
5/24/2000 12:00:12 AMB. Grier
7/18/2000 10:29:53 PMjonathan
: Have an old Philco Model 40-105 radio.
: appreciated.
10/31/1999 8:33:35 AMEloy González
: Need information and schematics for Philco P-5106E tube autoradio.
Thanks for all!
9/5/2000 12:04:57 PMPhilco radio combination built-in recorderplayer
: : Need information and schematics for Philco P-5106E tube autoradio.
: Thanks for all!
10/11/2000 8:19:01 PMjose lapetina
I request information on accessory contendor of CD for the autoradio MD4500.
: Thanks for all!
11/2/2000 2:28:01 PMGustavo
I have an automovil Chevrolet Vectra 97, with a radio Philco DC 227 integrated to the car's computer.
I want to replace it with a similar equipment bat whit CD. What model of radio CD do I have to buy?
12/3/1999 2:33:16 PMRod
: I need a schmatic for a philco radio model 38-4
10/12/2000 7:04:27 PMmark d. elliott
model 37630 floor model
11/21/2000 10:02:02 PMDennis Krumenauer
Model 48-1262 Philco Floor model Radio. What is the price on this radio?
Thanks.
1/23/2001 5:10:57 PMCharlotte Lewis
: I have a Philco floor model radio combination arecord player. It has a felt turn table and only plays 10 or 12 inch records. I have not had any luck finding out any information on it. The model number is 49-1611 code 121. Anyone know?
4/26/2002 11:15:33 AMGilbert Endrizzi
: : I have a Philco floor model radio combination arecord player. It has a felt turn table and only plays 10 or 12 inch records. I have not had any luck finding out any information on it. The model number is 49-1611 code 121. Anyone know?
2/20/2001 3:15:20 PMBohdan Uszkalo
I recently purchased a Phillips Type 725 Radio. I would like some idea about when it was made and it's value today. Thank you.
10/27/2001 11:21:46 PMMike Smith
I have a Philco model 38-116 radio in ecxelent condition both cabinet and chasis most all parts are original, with the exception of a couple tubes and some capasitors.I know some of the history and the people that owned this radio origianaly. I am a lover of old radios, but am no engineer by any stretch of the imagination, but am interested because I have been an agriculture brodcaster for over twenty years and my Philco 38-116 is my pride and joy. If you would could you please give me an appraisal with the information that I have given you. thank you very much.
Sincerely,
Mike Smith
11/20/2001 8:58:17 AMLew Rogers
Looking for the knobs for a Philco 37-650, where can I get them?
