40 miles really isn't too far away for FM, as all of suburbia here in Milwaukee picks up stations located in downtown Milwaukee just fine. Most of the suburbs are about 35 to 40 miles away. Reception can be weak at times. If you have some objects blocking the signal, though, or if the signal is weak, then it could be quite a distance to travel. If you have all of the components in that radio working as they should (precisely), you can try going over the different adjustments on the radio with a signal generator. You're really supposed to go over the IF cans with a sweep generator that puts out a wide bandwidth signal. This maintains the high fidelity of the set. However, if no such instrument is available, a regular signal generator can do a fair job for you. Most FM IFs are aligned at 10.7 MC. It could be that you just live in a funky area, it could be that your circuits are out of tune, or it could be that there is a faulty component somewhere in the radio. Be very careful when adjusting an FM radio. Unless you know exactly what you're doing, you can sometimes mess things up a bit. RF in the megacycle region is very sensitive. Keep track of what you do and undo.
Anyway, don't want to confuse you or something, but be accurate when tuning the radio, especially when working with FM. Since you say that the radio had critical components missing from it, then it was likely tampered with, and it is probable that the circuits have been tampered with as well.
Just so that you know, the high fidelity of an FM receiver is achieved by passing a wider band of freqencies than AM radios do. A typical AM radio passes like 10 KC of information through its circuits. When this is rectified by the detector, you only get about 5 kc of information, which is why the music sounds kind of crappy. FM uses circuits that pass about 19 MC of information, so almost all of the frequencies which we hear pass through. With a sweep generator and an oscilloscope you are able to tune the IF transformers of an FM radio to pass this more broad band of frequencies. Instead of simply producing the 10.7 MC IF signal, the sweep generator produces a signal that deviates about 9.5 MC either way of this signal (sweeps back and forth), allowing you to tune the circuits until all of this signal can be passed. Using a conventional signal generator will cause you to peak the transformers on a much narrower bandwidth. If you run into distortion or the music lacks the high end, you can try staggering the primary and secondary of each transformer just a tiny bit one way and the other (alternate).
::T. thanks thomas i don't have a sweep generater but i did align it with a signal gen. and a fluke dvm it works but not without a short lenth of wire on the fm ant. i may go through it again when i adjusted the fm discriminater i kept getting gain until one screw was all the way in so i'm sure something is still not right. butch
