Looking for Schematic for Zenith model MH2600 hi-fi
11/9/2004 11:50:50 PMBrandon
I found this old radio-phonograph console that is in pretty good shape and I can't find the schematic for it or any information on it whatsoever. I was on the zenith oracle website with no luck. On the back of the wooden console it says Model MH2600, chassis 3H01 and 9H21. Inside there are two white tags glued to the wood. The top says Model MHT-14, chassis 9H21 and corresponds to the chassis attached to the radio. It has nine tubes with the complement: 6BA6, 6BE6, 6BA6, 6AU6, 6W8A, 6BC7, 6BN8. It has years from 1946-1951 on it. The chassis itself has S190371 stamped into the metal and 111407 inked on it.
The bottom tag says chassis 3H01. It's complement is 12AX7A, 50FE5, 50FE5. This chassis seems to be the amplifier and has tone and volume controls. It has S245640 stamped into the metal and 112103 inked on it.
If someone could give me any information on this, or direct as to where I could get some information it would be much appreciated. I am thinking about either attempting to get it working properly or turning it into a guitar amplifier of some sort.
Thanks in advance.
11/10/2004 10:53:35 AMNorm Leal
Hi Brandon
This is a Zenith from around 1963. Sam's Photofact has information on your radio. The numbers you list show up in different Sam's packages. MH2600 is listed in Sam's Photofact #650-10, MHT-14 in 638-15, 3H01 in 603-16, 9H21 in 638-15.
This information can usually be ordered through a local library. Even if they don't have it at branch libraries most can order information from a central location. Sam's will sell data by calling 800-428-7267.
:I found this old radio-phonograph console that is in pretty good shape and I can't find the schematic for it or any information on it whatsoever. I was on the zenith oracle website with no luck. On the back of the wooden console it says Model MH2600, chassis 3H01 and 9H21. Inside there are two white tags glued to the wood. The top says Model MHT-14, chassis 9H21 and corresponds to the chassis attached to the radio. It has nine tubes with the complement: 6BA6, 6BE6, 6BA6, 6AU6, 6W8A, 6BC7, 6BN8. It has years from 1946-1951 on it. The chassis itself has S190371 stamped into the metal and 111407 inked on it.
:The bottom tag says chassis 3H01. It's complement is 12AX7A, 50FE5, 50FE5. This chassis seems to be the amplifier and has tone and volume controls. It has S245640 stamped into the metal and 112103 inked on it.
:If someone could give me any information on this, or direct as to where I could get some information it would be much appreciated. I am thinking about either attempting to get it working properly or turning it into a guitar amplifier of some sort.
:Thanks in advance.
11/10/2004 12:24:18 PMBrandon
Thanks Norm. That should do the trick.
:Hi Brandon
: This is a Zenith from around 1963. Sam's Photofact has information on your radio. The numbers you list show up in different Sam's packages. MH2600 is listed in Sam's Photofact #650-10, MHT-14 in 638-15, 3H01 in 603-16, 9H21 in 638-15.
: This information can usually be ordered through a local library. Even if they don't have it at branch libraries most can order information from a central location. Sam's will sell data by calling 800-428-7267.
::I found this old radio-phonograph console that is in pretty good shape and I can't find the schematic for it or any information on it whatsoever. I was on the zenith oracle website with no luck. On the back of the wooden console it says Model MH2600, chassis 3H01 and 9H21. Inside there are two white tags glued to the wood. The top says Model MHT-14, chassis 9H21 and corresponds to the chassis attached to the radio. It has nine tubes with the complement: 6BA6, 6BE6, 6BA6, 6AU6, 6W8A, 6BC7, 6BN8. It has years from 1946-1951 on it. The chassis itself has S190371 stamped into the metal and 111407 inked on it.
::The bottom tag says chassis 3H01. It's complement is 12AX7A, 50FE5, 50FE5. This chassis seems to be the amplifier and has tone and volume controls. It has S245640 stamped into the metal and 112103 inked on it.
::If someone could give me any information on this, or direct as to where I could get some information it would be much appreciated. I am thinking about either attempting to get it working properly or turning it into a guitar amplifier of some sort.
::Thanks in advance.
4/11/2008 4:28:07 PMtony
:Thanks in advance.
