Try adding a cap between the AC line and chassis of your radio. A .01 mfd @ 600 volts should do the job. This usually eliminates modulation hum heard when a radio is tuned to a station.
Philco model A-361 was made from a car radio. Car radios usually have slug tuning.
:I am restoring a Philco A-361 for my stepmother. I have replaced all the paper caps as well as the electrolytics. I have also replaced the resistors that were out of spec. The radio has a humming problem above about 1320 on the dial. The hum will intensify when I tune it into a station. The radio works clearly with no hum below 1320 on the dial. It doesn't have the usual tuning condenser with metal plates, but uses slug tuning. Any ideas as to what could cause this?
:Hi Brian
: Try adding a cap between the AC line and chassis of your radio. A .01 mfd @ 600 volts should do the job. This usually eliminates modulation hum heard when a radio is tuned to a station.
: Philco model A-361 was made from a car radio. Car radios usually have slug tuning.
::I am restoring a Philco A-361 for my stepmother. I have replaced all the paper caps as well as the electrolytics. I have also replaced the resistors that were out of spec. The radio has a humming problem above about 1320 on the dial. The hum will intensify when I tune it into a station. The radio works clearly with no hum below 1320 on the dial. It doesn't have the usual tuning condenser with metal plates, but uses slug tuning. Any ideas as to what could cause this?
:Hi Brian
Ideally it would be neutral side of the AC line but try either side. Some radios have a cap from each side of the AC power line to chassis.
:By AC line do you mean the actual power line or something else. If the power line, which side?
::Hi Brian
:: Try adding a cap between the AC line and chassis of your radio. A .01 mfd @ 600 volts should do the job. This usually eliminates modulation hum heard when a radio is tuned to a station.
:: Philco model A-361 was made from a car radio. Car radios usually have slug tuning.
:::I am restoring a Philco A-361 for my stepmother. I have replaced all the paper caps as well as the electrolytics. I have also replaced the resistors that were out of spec. The radio has a humming problem above about 1320 on the dial. The hum will intensify when I tune it into a station. The radio works clearly with no hum below 1320 on the dial. It doesn't have the usual tuning condenser with metal plates, but uses slug tuning. Any ideas as to what could cause this?
:Hi Brian
: Ideally it would be neutral side of the AC line but try either side. Some radios have a cap from each side of the AC power line to chassis.
::By AC line do you mean the actual power line or something else. If the power line, which side?
:::Hi Brian
::: Try adding a cap between the AC line and chassis of your radio. A .01 mfd @ 600 volts should do the job. This usually eliminates modulation hum heard when a radio is tuned to a station.
::: Philco model A-361 was made from a car radio. Car radios usually have slug tuning.
::::I am restoring a Philco A-361 for my stepmother. I have replaced all the paper caps as well as the electrolytics. I have also replaced the resistors that were out of spec. The radio has a humming problem above about 1320 on the dial. The hum will intensify when I tune it into a station. The radio works clearly with no hum below 1320 on the dial. It doesn't have the usual tuning condenser with metal plates, but uses slug tuning. Any ideas as to what could cause this?
:Thanks. I'll try that out when I get home tonight
::Hi Brian
:: Ideally it would be neutral side of the AC line but try either side. Some radios have a cap from each side of the AC power line to chassis.
:::By AC line do you mean the actual power line or something else. If the power line, which side?
::::Hi Brian
:::: Try adding a cap between the AC line and chassis of your radio. A .01 mfd @ 600 volts should do the job. This usually eliminates modulation hum heard when a radio is tuned to a station.
:::: Philco model A-361 was made from a car radio. Car radios usually have slug tuning.
::::Norm
:::::I am restoring a Philco A-361 for my stepmother. I have replaced all the paper caps as well as the electrolytics. I have also replaced the resistors that were out of spec. The radio has a humming problem above about 1320 on the dial. The hum will intensify when I tune it into a station. The radio works clearly with no hum below 1320 on the dial. It doesn't have the usual tuning condenser with metal plates, but uses slug tuning. Any ideas as to what could cause this?
