Dave, I'll check it out tonight and let you know. Thanks
Dave,
I believe the chassis number is 640339-4. Does this sound right?
Dave,
I found another number near the transformer. It is 214 06 00. Does this one look right?
Dave,
Are you out there?
Dave,
The number on the transformer is 300209-6-606-8-06.
:My son fried the transformer on this model by plugging it into a 220V outlet. Does anyone know what type of transformer this used so that I can repair it? Specifically, I need to know what voltage the transformer steps down to (from 110 V AC). Any help is greatly appreciated.
Bill,
I don't believe anything else was fried except the tranformner. You got the number right on the transformer. It is 300209-6-606-8-06. Do you know how I can get ahold of a replacement tranformer?
::Kevin, your chassis number is R214-06-00, SAMS Set 878, Folder 6. On the transformer, at least one of the numbers should be 300209-6. Tho with Magnavox I wouldn't bet on anything. I believe you have a good chance of getting the transformer, but did anything else go up in smoke with it.
:::My son fried the transformer on this model by plugging it into a 220V outlet. Does anyone know what type of transformer this used so that I can repair it? Specifically, I need to know what voltage the transformer steps down to (from 110 V AC). Any help is greatly appreciated.
:Bill,
:I don't believe anything else was fried except the tranformner. You got the number right on the transformer. It is 300209-6-606-8-06. Do you know how I can get ahold of a replacement tranformer?
Bill,
I tried to send you email but it failed at the address you gave me. The dimensions of the transformer are as follows:
Metal plates measure 2 5/8” (H) x 2 3/16” (W) x 1 1/8” thick
Mounting plates holes (4) are 1 ¾” apart
There are also a total of 7 wires coming from the transformer.
I tried looking at Hammond for one but don't know what the specs are for the one I have. Do you have that information?
::Kevin, I believe one way is to get parts is on radio related sites allowing you to post wanted ads. One is Antique Radio. Check the links on this site. Do a search. Hammond Transformer might have one that will work. You could even end up with a parts set from your area. Also, I don't think Magnavox changed the specs on the power transformer that much over the production time of the Astro-Sonic. Part numbers, yes. Of course it needs to fit, mount right. I have a 300252-1, secondaries 27-0-27 and 6. If you send me the dimensions, bsrhicks at yahoo dot com I'll compare. We'll go from there.
::Bill
::::Kevin, your chassis number is R214-06-00, SAMS Set 878, Folder 6. On the transformer, at least one of the numbers should be 300209-6. Tho with Magnavox I wouldn't bet on anything. I believe you have a good chance of getting the transformer, but did anything else go up in smoke with it.
:::::My son fried the transformer on this model by plugging it into a 220V outlet. Does anyone know what type of transformer this used so that I can repair it? Specifically, I need to know what voltage the transformer steps down to (from 110 V AC). Any help is greatly appreciated.
:::Bill,
:::I don't believe anything else was fried except the tranformner. You got the number right on the transformer. It is 300209-6-606-8-06. Do you know how I can get ahold of a replacement tranformer?
:Bill,
:I tried to send you email but it failed at the address you gave me. The dimensions of the transformer are as follows:
:Metal plates measure 2 5/8” (H) x 2 3/16” (W) x 1 1/8” thick
:Mounting plates holes (4) are 1 ¾” apart
:There are also a total of 7 wires coming from the transformer.
:I tried looking at Hammond for one but don't know what the specs are for the one I have. Do you have that information?
Bill,
I checked with Hammond and they would have to sell me two different transformers. Do you have one available for sale and if so, how much?
Kevin, I only have the 300252-1 as mentioned in this posting. If you want it e-mail me at shedradios at yahoo dot com with your address. Then I'll make you a deal, a good one.
Bill
I finally hooked up the new transformer and everything works great. The one you sold me had the same color wires so it was easy to re-connect. Thanks for your help.
:::I see...Sorry about that Kevin. E-mail is shedradios at yahoo dot com. Your transformer primary is 117 VAC @ .18A AC, secondaries are 54 VAC CT @ .22A DC and 6.3 VAC @ .45A AC per parts list. The dimensions on yours are same as the one I have. Same number of leads.
:::::Kevin, I believe one way is to get parts is on radio related sites allowing you to post wanted ads. One is Antique Radio. Check the links on this site. Do a search. Hammond Transformer might have one that will work. You could even end up with a parts set from your area. Also, I don't think Magnavox changed the specs on the power transformer that much over the production time of the Astro-Sonic. Part numbers, yes. Of course it needs to fit, mount right. I have a 300252-1, secondaries 27-0-27 and 6. If you send me the dimensions, bsrhicks at yahoo dot com I'll compare. We'll go from there.
:::::Bill
:::::::Kevin, your chassis number is R214-06-00, SAMS Set 878, Folder 6. On the transformer, at least one of the numbers should be 300209-6. Tho with Magnavox I wouldn't bet on anything. I believe you have a good chance of getting the transformer, but did anything else go up in smoke with it.
::::::::My son fried the transformer on this model by plugging it into a 220V outlet. Does anyone know what type of transformer this used so that I can repair it? Specifically, I need to know what voltage the transformer steps down to (from 110 V AC). Any help is greatly appreciated.
::::::Bill,
::::::I don't believe anything else was fried except the tranformner. You got the number right on the transformer. It is 300209-6-606-8-06. Do you know how I can get ahold of a replacement tranformer?
::::Bill,
::::I tried to send you email but it failed at the address you gave me. The dimensions of the transformer are as follows:
::::Metal plates measure 2 5/8” (H) x 2 3/16” (W) x 1 1/8” thick
::::Mounting plates holes (4) are 1 ¾” apart
::::There are also a total of 7 wires coming from the transformer.
::::I tried looking at Hammond for one but don't know what the specs are for the one I have. Do you have that information?
::Bill,
::I checked with Hammond and they would have to sell me two different transformers. Do you have one available for sale and if so, how much?
:Kevin, I only have the 300252-1 as mentioned in this posting. If you want it e-mail me at shedradios at yahoo dot com with your address. Then I'll make you a deal, a good one.
:Bill
