50Y6 which pins for dail lamp
11/2/2004 2:30:25 AMradiomad
this is similar to another question i have just seen can anyone tell me the correct pins to wire up a dail lamp to this valve, cheers.
11/2/2004 10:16:34 AMThomas Dermody
Read my last reply to David Jones. This is the correct method for the 50Y6 tube. I thought I originally read 35Z5, but I was wrong. My final reply explains how to wire a pilot lamp into a radio with the 50Y6 tube. The 50Y6 tube does not have a pilot lamp ballast, and so you must put in your own ballast.
Easily done. Fine results.
