All American Mohawk may be the manufacturer? Schematics can be found here:
http://www.nostalgiaair.org/Resources/018/T0000018.htm
Unlikely two tubes would have gone bad at the same time. Check filament solder connections. Two tubes wired to the speaker could be #45? They were often used in push pull to drive a speaker.
:The first two tubes in this radio went dark, looks like they are wire to the speaker jack. This radio has a wood tabletop cabinet. Anyone know what might be wrong with it? What model is it?
:9 TTL TUBES
:HEAVY
:TRF?
The rectifier should be an 80 tube. Since your radio uses 24 & 71 tubes it was most likely built in 1929. Just about any circuit using the same tubes will be close. Even a circuit with 45 output tubes should help. The 45 has 2.5 volt filament while 71 is 5 volts.
You mention an audio transformer primary failure driving your 71's. AES, www.tubesandmore.com sells replacement audio interstage transformers (A53C). You could also connect a 22K across the open primary and a cap from the driving tube plate to one output tube grid. The secondary of the transformer will invert the signal if you have a second output tube.
:Norm, thanks for your reply. This radio is an All American Mohawk tabletop witha wood cabinet that is long with a lid top that opens, no speaker, 9 tubes, the unlit tubes are 71, I think the rectifier tube is a 24, I can't tell which model it is. A Philco site has a fix for the Audio transformer primary failure to the 71's. Mabey the same circiut. Do you know which model this radio is? The cabinet looks similar to a Radiola. Thanks Norm.
:Hi Norm, one of the two 24 tubes filament is glowing very bright, mabey I should change it.
