I described a better condenser tester a couple of months ago. The procedure I described above is usually all you need to find a bad unit. If you wish, I'll explain the condenser tester circuit to you, though. It's easy, and if buit as a solid state unit instead of the tube I originally suggested for the rectifier, all the parts are available at Radio Shack for very little money.
:Philco model 42-327,this AM/SW works good except the am quits working , after checking it it appears by all accounts to be a bad solder joint at the oscilator coil, the terminal in question has the antenna transformer, and a couple mica caps attached to this joint, at first i thought was bad conection at the osc coil, so i removed and cheked it out found that it had good conection so I cleaned up the old solder and re soldered the caps and the antenna transformer ( this to appears to be ok) to it, it will play for hours but then slowly fade away, it also kills the push buttons as well, but SW play fine, if I take a screw driver and just touch the connection(at the osc coil) it pops back on, what the heck can it be? I have resoldered this connection and the other componets attached to this and corasponding joints but still the same problem sometimes will play for hours and sometimes only a few minutes, but either way I just lightly touch the lug and the radio comes back to life could it be one of the micas? since there is no way to check them and unfortuneatly I do not have any lying around to sub them so I have not persued this avenue as of yet but could it be one of these caps? Any ideas is appreciated.
:Thanks
So, yeah, check for stray voltages, resistors that have drifted or opened up. Those that connect to the control grid of a tube bias the grid, and if they drift high, the grid will eventually collect so many electrons from the cathode that it will become saturated, and the set will stop. Touching the grid will relieve some of the electrons through your finger, and set operation will begin again. Keep in mind that other things do this when resistors are drifted, or condensers are leaky.....not just grids.
Sometimes a screen grid buffer condenser can open up and allow the screen grid to oscillate. Screen grids, when connected indirectly to B+ through a resistor, can drift and throw a tube into oscillation if there isn't a condenser of significant value from the grid to B- to keep voltages stable.
Let me know what you are touching to get the radio to come back to life. Let me know if other terminals have the same results. Let me know the model number of your radio so I can look up the diagram (I forgot it if you already gave it).
P.S. You know how in the old days they used to bias the grids negative with a battery? Well, another method used with output tubes puts a resistor in series with the cathode so that the cathode is slightly positive with respect to B-. That biases the grid negative. Understandable.
Still another method is used in high impedance circuits, where you find the cathode tied directly to B-. I don't know if I ever explained this to you before, but by very nature of tube operation, as electrons stream past the control grid of a tube to the plate, some collect on the grid. If a condenser passes audio or RF currents to the grid, the grid will receive these currents, but as you know, condensers don't pass direct current. That said, the electrons that build up on the control grid from natural tube operation will eventually build up to such a degree that the grid is so negative that the tube stops functioning. If a resistor is placed from the grid to B- of a relatively high value, some of the electrons can be leaked off, and the grid can be kept at a fairly constant negative level (with no signal applied). Often the grid biasing (leak) resistor that you find on the first audio amp. tube will be around 1 to 10 meg. On the primary grid of the oscillator tube, it'll be more around 15 to 100k. (Some circuits lay out the oscillator differently, and no resistor is used.) If the resistor specified for a certain tube drifts in value, the grid will be allowed to go more negative. If the condenser that connects to the grid leaks, whatever voltage is on the other side of this condenser will also affect the grid voltage either positively or negatively, depending on what's on the other side. So if either the resistor or condenser are faulty, this will affect the bias of the grid.
The antenna grid on the oscillator, however, receives its negative voltage through the antenna coil from the AVC circuit. The AVC circuit serves as a sort of negative C battery. The antenna coil is of such low impedance that electrons cannot normally build up on the antenna grid.
