Tube substitution for 1L6
10/13/2004 7:25:44 PMJohn D. Weeks
Hey guys
Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/13/2004 9:44:06 PMSteve - W9DX
You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
:Hey guys
:Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/13/2004 10:54:28 PMNorm Leal
Hi
You can try a 1U6 but be sure to add a resistor across the filament before turning the radio on. A 1U6 will burn out on turn as it has a lower current filament.
In Zenith T/O's a 1R5 will work for broadcast band. It won't oscillate on higher short wave frequencies. If you are bringing up a T/O best to use the 1R5, much lower cost than a 1L6.
Other tubes such as 1LA6 and 1LC6 can work but req
:You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
::Hey guys
::Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/13/2004 10:57:53 PMNorm Leal
:Hi
: You can try a 1U6 but be sure to add a resistor across the filament before turning the radio on. A 1U6 will burn out on turn as it has a lower current filament.
: In Zenith T/O's a 1R5 will work for broadcast band. It won't oscillate on higher short wave frequencies. If you are bringing up a T/O best to use the 1R5, much lower cost than a 1L6.
: Other tubes such as 1LA6 and 1LC6 can work but reqire building an adapter. Bill Turner sells adapters. His email dialcover@webtv.net .
::You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
:::Hey guys
:::Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/14/2004 11:12:31 AMJohn D. Weeks
::Hi
Thanks, what size resitor do I use with the 1U6?
:: You can try a 1U6 but be sure to add a resistor across the filament before turning the radio on. A 1U6 will burn out on turn as it has a lower current filament.
:: In Zenith T/O's a 1R5 will work for broadcast band. It won't oscillate on higher short wave frequencies. If you are bringing up a T/O best to use the 1R5, much lower cost than a 1L6.
:: Other tubes such as 1LA6 and 1LC6 can work but reqire building an adapter. Bill Turner sells adapters. His email dialcover@webtv.net .
:::You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
::::Hey guys
::::Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/15/2004 9:51:27 AMNorm Leal
Hi John
A 1U6 draws .025 amps at 1.4 volts, While a 1L6 draws .05 amps. When using a 1U6 you must draw another .025 amps with the resistor.
1.4 volts divided by .025 amps = 56 ohms. A resistor around 56 ohms should be added across the filament, pins #1 and #7, of the 1U6.
:::Hi
:Thanks, what size resitor do I use with the 1U6?
::: You can try a 1U6 but be sure to add a resistor across the filament before turning the radio on. A 1U6 will burn out on turn as it has a lower current filament.
::: In Zenith T/O's a 1R5 will work for broadcast band. It won't oscillate on higher short wave frequencies. If you are bringing up a T/O best to use the 1R5, much lower cost than a 1L6.
::: Other tubes such as 1LA6 and 1LC6 can work but reqire building an adapter. Bill Turner sells adapters. His email dialcover@webtv.net .
::::You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
:::::Hey guys
:::::Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
10/16/2004 1:38:40 AMJohn D. Weeks
Thanks Norm. I will try this, if it is found that I need to buy a new tube.
Hi John
: A 1U6 draws .025 amps at 1.4 volts, While a 1L6 draws .05 amps. When using a 1U6 you must draw another .025 amps with the resistor.
: 1.4 volts divided by .025 amps = 56 ohms. A resistor around 56 ohms should be added across the filament, pins #1 and #7, of the 1U6.
::::Hi
::Thanks, what size resitor do I use with the 1U6?
:::: You can try a 1U6 but be sure to add a resistor across the filament before turning the radio on. A 1U6 will burn out on turn as it has a lower current filament.
:::: In Zenith T/O's a 1R5 will work for broadcast band. It won't oscillate on higher short wave frequencies. If you are bringing up a T/O best to use the 1R5, much lower cost than a 1L6.
:::: Other tubes such as 1LA6 and 1LC6 can work but reqire building an adapter. Bill Turner sells adapters. His email dialcover@webtv.net .
:::::You can try a 1U6 as substitute. It has the 7DC basing. Click on Tubes on this website and enter the tube type for more info.
::::::Hey guys
::::::Is there a substitution for the 1L6 tube in the Zenith Trans-Oceanic B600? Thanks
