Philips radio
10/13/2004 10:54:17 AMMauricio
Just received a Philips radio (Bi-ampli) with turntable in wood case about 3 ft by 4 ft wide and 3 deep. It has tubes internally but that is all the information that I have. How do i find out the model number (no numbers on outside anywhere) Thanks
10/13/2004 11:55:17 AMThomas Dermody
If you know electrically, how it is wired under the chassis, and you know the tube layout, you can search similar diagrams until a matching one is found. This takes a while, but I have done it several times when I have nothing else to do, and have come up with a model number each time.
:Just received a Philips radio (Bi-ampli) with turntable in wood case about 3 ft by 4 ft wide and 3 deep. It has tubes internally but that is all the information that I have. How do i find out the model number (no numbers on outside anywhere) Thanks
10/13/2004 6:18:26 PMRobert Sarbell
Mauricio,
If you can provide the number/type of tubes, I believe we can arrive at the model designations with the "F" or "H" categories for the bi-ampl chasses. . .they essentially began in 1955 with a fabulous model BX998A bi-ampl. The bass and treble frequencies were amplified seaparately, typicall using an EL84 for the treble and bass fgrequencies through a series-balanced stage using 2 PL81s or similar tubes.
I believe they did [produce a model FX995A which designates a "floor" model using the same VERY elegant chassis.
Respectfully,
Robert
10/26/2004 11:00:52 AMMauricio
I will look at the tubes and layout and get back....Thanks for the help...
