If this radio uses small IF Transformer, less than 1" square, with one adjustment on top & bottom, they have built in silver mica caps. These caps can short over time and give static. It usually gets worse as a radio heats until only static is heard.
Caps can be dug out of the base of an IF Transformer. New external caps around 100pf should be added.
:I am trying to restore a Silvertone model 132.881. This is an AA5 of about 1950 vintage. When I first got the set it wasn't working and the chassis was in awful shape. A few resistors had been replaced with the wrong values, the IF coil was open, and various other problems.
:I have repaired the IF coil, replaced all of the tubes "twice", replaced "all" of the resistors, and replaced all of the caps except for one mica filtering cap in the detector stage. Now for the problem! The radio fires up and is fairly selective, but it has a small bit of static across the dial. After it plays for about five or six minutes the static increases and finally there's no signal anymore, only static. If I turn the set off for about five minutes and then turn it back on it will play again just as before, but this time, it plays for a shorter period of time. If I leave it off for a half hour or more, then it will play again for about five or six minutes again before fading to static. I figure the problem is heat sensitive, but I have no idea as to where to start. I'm new to radio restoration, so I'm open for any help anyone can give.
Never overlook mica condensers. Another little wonder you'll find is that sometimes they aren't even mica. All of the supposedly mica condensers in my 630TS television were leaky and caused tons of trouble (sputterning, picture jumping, you name it). Cracked them open and they were PAPER CONDENSERS! The bakelite condensers with the colored dots are on occasion paper. There is a color code for this that is occasionally marked on the condenser. I forgot what it is. More likely, though, you have mica condensers, which do fail on rare occasion.
T.D.
