If so there are three things that fail most commonly in these sets, and are in no particular order:
1) Contact resistance of the power relay- if it is high, or if the relay coil connections where they are soldered to the foil strip are not sound, bith can cause some problems.
2) "cold" solder joints in the set, mainly around the power supply and the sweep circuits.
3) The "HOT" (Horizontal Output Transistor)- This is the big one on the heat sink. Check it for leakage. If you do not have have a transistor tester, uses a good DMM, or other reliable meter that will allow you to measure up to at least 1 MegOhm, and check across all three connections. Two at a time. A transistor is essentially a pair of diodes with two leads tied together (as a rudimentary explanation, there is far more to transistor theory but as the most basic explanation, this works) Assuming it is a standard "TO-3" case style, the case will be the collector.
With your positive lead for the meter attached to the case, check the Emitter, and Base, with the negative lead- note your resistance values. Now, reverse the leads and repeat the measurements. If you do not have a great amount of difference, across any of the terminals tested at this point- a difference of at least 10:1 to 15:1 or greater, the transistor is breaking down, and is the likely cause of your problem. *Base to Collector resistance values will be lower than the Emitter to collector values, but close to those of Base to Emitter values*. If these(collector to base/collector to emitter/base to collector/emitter to collector) measurements are acceptable, check for Base to Emitter leakage- the same procedure as before, but you are testing just between the Base lead and the Emitter lead. If the results here do not reflect the same level of diference, the transistor is still failing.
: Emerson Model # TC1972DB It shuts off after 30 seconds Of being powered on.
: Can anybody help me to identified this problem?
The picture really looks good BUT on the screen it has the CHSET in the left corner and the CH # on the right corner on the screen all the time. I do not have the remote for it. I was wondering if there is a way to take this off of the screen. I tried a remote, (70-20910) that is for an Emerson product but not this particular Tv--it didn't work. I also tried all the codes from an universal remote but they wouldn't program this TV
