I would appreciate any info on this.
Thank you
Jeff
:Hello,
:I am a newbie to radio repair but I have a GE E-105 radio that was my grandfathers and I want to restore it. All the tubes have been removed. Does anyone know where I could buy replacement tubes? I am not even sure which tubes I need but I am trying to track down a schematic to help me with that one.
:I would appreciate any info on this.
:Thank you
:Jeff
As all the tubes were removed, it is likely that something is wrong with the set. I strongly recommend replacing, or at least testing all condensers before powering up the set, and since you're a "newbe" to antique radio repair, you probably havn't heard of the method commonly used to slowly power up a set. To do so, take a board, and mount a light socket and an outlet on it. Wire them in series and attach a line cord. Plug in the radio into the outlet, and screw in a 60 watt bulb. Start with all tubes removed and check brightness of bulb with set on. Full brightness indicates short. Medium brightness also indicates some sort of short. Dim or nothing means everything's probably good. Put in the tubes, and slowly increase the wattage of the bulb. The bulb should not glow full brightness with tubes in place, if the bulb is equivilant to the wattage of the set or higher. If it glows full brightness, then you have shorts (such as electrolytics). Look for smoke and other problems as you raise the wattage of the bulb. Observe the rectifier plates. They should not glow at all.
:For tubes you could contact radiodaze.com, e-mail pmh@radiodaze.com and tell them what chassis and or model number you have and they can tell you what tubes you will need and usually they have the tubes for sale.
::Hello,
::I am a newbie to radio repair but I have a GE E-105 radio that was my grandfathers and I want to restore it. All the tubes have been removed. Does anyone know where I could buy replacement tubes? I am not even sure which tubes I need but I am trying to track down a schematic to help me with that one.
::I would appreciate any info on this.
::Thank you
::Jeff
Thanks again.
:The circuit diagram is in the Resources section of this web site. Tubes are: 5Z4, 6K7, 6K7, 6K7, 6A8, 6J7, 6H6, 6C5, 6F5, 6L6. The audio and rectifier tubes may be glass (5Z4, 6F5, 6L6), and should be of the G style, given the year your radio was made. If shields are available within the set (they're still present), you may also use G style tubes throughout the RF sections. If shields are not present, it is better to use metal tubes in the RF section, and leave the G off the ends of those tube numbers when ordering. Still, glass looks nice, and if you wish, you may try glass tubes in the RF section, and see how the set operates.
:As all the tubes were removed, it is likely that something is wrong with the set. I strongly recommend replacing, or at least testing all condensers before powering up the set, and since you're a "newbe" to antique radio repair, you probably havn't heard of the method commonly used to slowly power up a set. To do so, take a board, and mount a light socket and an outlet on it. Wire them in series and attach a line cord. Plug in the radio into the outlet, and screw in a 60 watt bulb. Start with all tubes removed and check brightness of bulb with set on. Full brightness indicates short. Medium brightness also indicates some sort of short. Dim or nothing means everything's probably good. Put in the tubes, and slowly increase the wattage of the bulb. The bulb should not glow full brightness with tubes in place, if the bulb is equivilant to the wattage of the set or higher. If it glows full brightness, then you have shorts (such as electrolytics). Look for smoke and other problems as you raise the wattage of the bulb. Observe the rectifier plates. They should not glow at all.
:Thomas
::For tubes you could contact radiodaze.com, e-mail pmh@radiodaze.com and tell them what chassis and or model number you have and they can tell you what tubes you will need and usually they have the tubes for sale.
:::Hello,
:::I am a newbie to radio repair but I have a GE E-105 radio that was my grandfathers and I want to restore it. All the tubes have been removed. Does anyone know where I could buy replacement tubes? I am not even sure which tubes I need but I am trying to track down a schematic to help me with that one.
:::I would appreciate any info on this.
:::Thank you
:::Jeff
Thanks again
Jeff
:Thomas
:::Hello,
:::Thank you
:::Jeff
To test condensers, take your multi-meter (available at Radio Shack) and set it to the highest resistance measurement setting (the one that you can raise the needle with your bare hands by touching both leads). Place the condenser to be tested across the leads. With electrolytics it is best to have the polarity correct, that is, positive lead to the positive terminal on condenser, and negative lead to negative on condenser. Electrolytics will cause the needle to swing high and slowly fall back down to infinity. Anything above about 5 MFD should swing really high. If not, the electrolytic has dried up, and should probably be replaced. Substitute a new one and note difference in radio performance. When testing smaller condensers (.1 and lower), the needle will not swing very high at all. At ratings of .001 and less, no needle movement may be noticed. What is important with all condensers is that the needle return to exactly infinity. With electrolytics, this may take some time, and actually is not so critical. A few million ohms leakage is acceptable. With the smaller paper units, any leakage is critical. The needle must swing back to absolutely where it started, or the condenser is leaky, and bad. If testing a really small condenser, it is not likely that the needle will swing up and down, but it will still move up just a little and stay up if the condenser is bad. You must have a good eye to notice some leaks. You can also build a condenser shorts tester, which I have written up elsewhere in this month's forum.
That's it with condensers. Otherwise there is the usual testing of resistor values and checking coils and transformers for open windings, etc.
Hope this helps. Hopefully your radio will just turn on and play, and nothing will be wrong.
:Thank you very much for the info.....very informative!
:Are the condensors the three devices in the aluminum cases (two are round and one square)?
:Thanks again
:Jeff
::The circuit diagram is in the Resources section of this web site. Tubes are: 5Z4, 6K7, 6K7, 6K7, 6A8, 6J7, 6H6, 6C5, 6F5, 6L6. The audio and rectifier tubes may be glass (5Z4, 6F5, 6L6), and should be of the G style, given the year your radio was made. If shields are available within the set (they're still present), you may also use G style tubes throughout the RF sections. If shields are not present, it is better to use metal tubes in the RF section, and leave the G off the ends of those tube numbers when ordering. Still, glass looks nice, and if you wish, you may try glass tubes in the RF section, and see how the set operates.
::As all the tubes were removed, it is likely that something is wrong with the set. I strongly recommend replacing, or at least testing all condensers before powering up the set, and since you're a "newbe" to antique radio repair, you probably havn't heard of the method commonly used to slowly power up a set. To do so, take a board, and mount a light socket and an outlet on it. Wire them in series and attach a line cord. Plug in the radio into the outlet, and screw in a 60 watt bulb. Start with all tubes removed and check brightness of bulb with set on. Full brightness indicates short. Medium brightness also indicates some sort of short. Dim or nothing means everything's probably good. Put in the tubes, and slowly increase the wattage of the bulb. The bulb should not glow full brightness with tubes in place, if the bulb is equivilant to the wattage of the set or higher. If it glows full brightness, then you have shorts (such as electrolytics). Look for smoke and other problems as you raise the wattage of the bulb. Observe the rectifier plates. They should not glow at all.
::Thomas
:::For tubes you could contact radiodaze.com, e-mail pmh@radiodaze.com and tell them what chassis and or model number you have and they can tell you what tubes you will need and usually they have the tubes for sale.
::::Hello,
::::I am a newbie to radio repair but I have a GE E-105 radio that was my grandfathers and I want to restore it. All the tubes have been removed. Does anyone know where I could buy replacement tubes? I am not even sure which tubes I need but I am trying to track down a schematic to help me with that one.
::::I would appreciate any info on this.
::::Thank you
::::Jeff
Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
:Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
:Yeah, I just noticed that. I think I was smoking crack or something while looking at the diagram.
::Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
One added twist is that I am currently living in Germany with the 220Volt issue. I have a good transformer but are there extra considerations I should watch out for due to the transformer thing?
:Unless you look at the circuit diagram very closely, the 6H6 looks like it's wired as a discriminator, which lead me to believe that the radio had FM. The radio also has AFC, or Automatic Frequency Control, which is usually only found on FM radios. Still, if I were to look at the diagram more closely, I'd realize that there aren't two separate sets of IF transformers necessary for AM and FM reception, and there also isn't a separate FM oscillator. Furthermore, the 6H6 is simply wired as a very elaborate AM detector. Pretty fancy AM radio. Bet when you get it running, it will surpass any ordinary AM radio. Sorry for the mistake.
:Thomas
::Yeah, I just noticed that. I think I was smoking crack or something while looking at the diagram.
:::Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
Many, many years ago, like when alternating current first appeared in the U.S.A., there was some reference to frequencies as high as something around 130 or 140 cycle current. I forgot the exact frequency. I doubt you will ever see anything like this to-day. If you do use your radio on a higher frequency than it was designed for (doubt you'll find any), it may have less power than normal, due to cancellations of the higher frequency within the transformer (choking action).
:Thomas/Steve,
:You guys are great...thanks for the info. I have been out of touch for awhile but I am in the process of buying the parts now.
:One added twist is that I am currently living in Germany with the 220Volt issue. I have a good transformer but are there extra considerations I should watch out for due to the transformer thing?
::Unless you look at the circuit diagram very closely, the 6H6 looks like it's wired as a discriminator, which lead me to believe that the radio had FM. The radio also has AFC, or Automatic Frequency Control, which is usually only found on FM radios. Still, if I were to look at the diagram more closely, I'd realize that there aren't two separate sets of IF transformers necessary for AM and FM reception, and there also isn't a separate FM oscillator. Furthermore, the 6H6 is simply wired as a very elaborate AM detector. Pretty fancy AM radio. Bet when you get it running, it will surpass any ordinary AM radio. Sorry for the mistake.
::Thomas
:::Yeah, I just noticed that. I think I was smoking crack or something while looking at the diagram.
::::Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
:You have a transformer that converts 220 to 110, or does the transformer in the radio have a 220 volt tap? Make sure that the current available where you live has the same frequency as the radio was designed for. Some high end radios had transformers that had both 50 and 60 cycle options. Otherwise, if your radio is designed for the standard 60 cycle current in the U.S.A., and you are now receiving 50 cycle, or some other lower frequency, you could overheat the transformer. I don't think anyone anywhere uses 25 cycle current. As the frequency goes down, your hum will be more noticeable, and as the frequency goes down, current will flow through the transformer windings more readily, as coils have less of a choking affect on lower frequencies. If you have 50 cycle current available, and the radio is made for 60, try operating the set for some time and keep constant monitor of the transformer to see how hot it gets. If it gets hot, you need a converter, or perhaps a different power transformer. Also, upon initially firing up the radio, check all voltages to see that they are about the same. If you experience a hot transformer, or high voltages, you could experiment with winding various ballast chokes of small inductance to be connected in series with the transformer primary. Once a correct value is found, it can be mounted somewhere within the radio.
:Many, many years ago, like when alternating current first appeared in the U.S.A., there was some reference to frequencies as high as something around 130 or 140 cycle current. I forgot the exact frequency. I doubt you will ever see anything like this to-day. If you do use your radio on a higher frequency than it was designed for (doubt you'll find any), it may have less power than normal, due to cancellations of the higher frequency within the transformer (choking action).
:Thomas
::Thomas/Steve,
::You guys are great...thanks for the info. I have been out of touch for awhile but I am in the process of buying the parts now.
::One added twist is that I am currently living in Germany with the 220Volt issue. I have a good transformer but are there extra considerations I should watch out for due to the transformer thing?
:::Unless you look at the circuit diagram very closely, the 6H6 looks like it's wired as a discriminator, which lead me to believe that the radio had FM. The radio also has AFC, or Automatic Frequency Control, which is usually only found on FM radios. Still, if I were to look at the diagram more closely, I'd realize that there aren't two separate sets of IF transformers necessary for AM and FM reception, and there also isn't a separate FM oscillator. Furthermore, the 6H6 is simply wired as a very elaborate AM detector. Pretty fancy AM radio. Bet when you get it running, it will surpass any ordinary AM radio. Sorry for the mistake.
:::Thomas
::::Yeah, I just noticed that. I think I was smoking crack or something while looking at the diagram.
:::::Thomas, the GE model E-105 is AM only covering the broadcast band, and 2 shortwave bands. Jeff, the chassis diagrams and underchassis wiring diagram in the Ryder's Service data on this site will show you the correct tube locations and which aluminum cylinders are condensers. There are 4 can style electrolytic condensers mounted on top of the chassis and shown in the schematics as C-18, C-20, C-46, and C-47. All four are single section caps (3 at 30 mfd, and 1 at 16 mfd). There's also a box style 3-section electrolytic under the chassis and shown on the schematic as C-53, C-55, and C-57. Study the schematics and diagrams in detail for a couple of days before diving into the repair. I helps to do some planning and mental restoration first before getting the wire cutters out. I'm working on the exact same model at this moment, and have gotten some great help and advice here.
:Hi!! I from Cordoba, Argentina (south america)
:Some months ago I restored a GE E-106, the power transformer, the "saturable core reactor" transformer of the "colorama tunning system" and some resistor were burned, now is working and it´s the best radio that I have the sound and the selectivity it´s just incredible!! if you need any help please mail me!!!
