Most likely a thermister, heat sensitive resistor. The glass cylinder may have carbon powder or small wire inside? Might be able to measure resistance with an ohm meter? Does the schematic show a value for this part?
:I have picked up a Layfette TE-22 Sine-Square Wave Audio Generator. The circuit diagram shows one component that I am trying to identify. The symbol on the schematic is of a resistor but with a circle drawn around it. One one schematic it has a 'Th' beside it and on another it has 'ST' beside it. When I picked this up I found, taped to the inside, a schematic and a glass cylinder (1/2" x 1/16"). This cylinder has two leads on it and nothing inside connecting the leads. I am pretty sure this is what is shown on the schematic as TH/ST but am not sure. It does not exist in the circuit and the oscillator does not start. I am thinking whoever had this before had this component go bad and removed it. Is it a fuse? or a special type of resistor?
:Any help would be appreciated.
:Thanks in advance.
:Leon
I was wondering if it was a thermister but both copies of schematics does not show a value. If there is a small wire still in the glass cylinder then it is very small. I have not checked it under a magnifying glass but will.
Thanks Norm.
:Hi Leon
: Most likely a thermister, heat sensitive resistor. The glass cylinder may have carbon powder or small wire inside? Might be able to measure resistance with an ohm meter? Does the schematic show a value for this part?
::I have picked up a Layfette TE-22 Sine-Square Wave Audio Generator. The circuit diagram shows one component that I am trying to identify. The symbol on the schematic is of a resistor but with a circle drawn around it. One one schematic it has a 'Th' beside it and on another it has 'ST' beside it. When I picked this up I found, taped to the inside, a schematic and a glass cylinder (1/2" x 1/16"). This cylinder has two leads on it and nothing inside connecting the leads. I am pretty sure this is what is shown on the schematic as TH/ST but am not sure. It does not exist in the circuit and the oscillator does not start. I am thinking whoever had this before had this component go bad and removed it. Is it a fuse? or a special type of resistor?
::Any help would be appreciated.
::Thanks in advance.
::Leon
:Hi Norm
:I was wondering if it was a thermister but both copies of schematics does not show a value. If there is a small wire still in the glass cylinder then it is very small. I have not checked it under a magnifying glass but will.
:Thanks Norm.
::Hi Leon
:: Most likely a thermister, heat sensitive resistor. The glass cylinder may have carbon powder or small wire inside? Might be able to measure resistance with an ohm meter? Does the schematic show a value for this part?
:::I have picked up a Layfette TE-22 Sine-Square Wave Audio Generator. The circuit diagram shows one component that I am trying to identify. The symbol on the schematic is of a resistor but with a circle drawn around it. One one schematic it has a 'Th' beside it and on another it has 'ST' beside it. When I picked this up I found, taped to the inside, a schematic and a glass cylinder (1/2" x 1/16"). This cylinder has two leads on it and nothing inside connecting the leads. I am pretty sure this is what is shown on the schematic as TH/ST but am not sure. It does not exist in the circuit and the oscillator does not start. I am thinking whoever had this before had this component go bad and removed it. Is it a fuse? or a special type of resistor?
:::Any help would be appreciated.
:::Thanks in advance.
:::Leon
This component is under the chassis of the TE-22. To have a lamp there would not make sense. No need for a fuse in this location either.....
Leon
:A resistor symbol with a circle is a lamp. If it looks like a fuse see if you can read volts and watts on end. Probably rated at 3 watts 115 V.
:Bill
::Hi Norm
::I was wondering if it was a thermister but both copies of schematics does not show a value. If there is a small wire still in the glass cylinder then it is very small. I have not checked it under a magnifying glass but will.
::Thanks Norm.
:::Hi Leon
::: Most likely a thermister, heat sensitive resistor. The glass cylinder may have carbon powder or small wire inside? Might be able to measure resistance with an ohm meter? Does the schematic show a value for this part?
::::I have picked up a Layfette TE-22 Sine-Square Wave Audio Generator. The circuit diagram shows one component that I am trying to identify. The symbol on the schematic is of a resistor but with a circle drawn around it. One one schematic it has a 'Th' beside it and on another it has 'ST' beside it. When I picked this up I found, taped to the inside, a schematic and a glass cylinder (1/2" x 1/16"). This cylinder has two leads on it and nothing inside connecting the leads. I am pretty sure this is what is shown on the schematic as TH/ST but am not sure. It does not exist in the circuit and the oscillator does not start. I am thinking whoever had this before had this component go bad and removed it. Is it a fuse? or a special type of resistor?
::::Any help would be appreciated.
::::Thanks in advance.
::::Leon
Lamps were used under a chassis not for light but as a thermistor. A lamp changes resistance as it heats.
:Hi Bill
:This component is under the chassis of the TE-22. To have a lamp there would not make sense. No need for a fuse in this location either.....
:Leon
::A resistor symbol with a circle is a lamp. If it looks like a fuse see if you can read volts and watts on end. Probably rated at 3 watts 115 V.
::Bill
:::Hi Norm
:::I was wondering if it was a thermister but both copies of schematics does not show a value. If there is a small wire still in the glass cylinder then it is very small. I have not checked it under a magnifying glass but will.
:::Thanks Norm.
::::Hi Leon
:::: Most likely a thermister, heat sensitive resistor. The glass cylinder may have carbon powder or small wire inside? Might be able to measure resistance with an ohm meter? Does the schematic show a value for this part?
::::Norm
:::::I have picked up a Layfette TE-22 Sine-Square Wave Audio Generator. The circuit diagram shows one component that I am trying to identify. The symbol on the schematic is of a resistor but with a circle drawn around it. One one schematic it has a 'Th' beside it and on another it has 'ST' beside it. When I picked this up I found, taped to the inside, a schematic and a glass cylinder (1/2" x 1/16"). This cylinder has two leads on it and nothing inside connecting the leads. I am pretty sure this is what is shown on the schematic as TH/ST but am not sure. It does not exist in the circuit and the oscillator does not start. I am thinking whoever had this before had this component go bad and removed it. Is it a fuse? or a special type of resistor?
:::::Any help would be appreciated.
:::::Thanks in advance.
:::::Leon
You'll find this lamp in the oscillator circuit. Heating and cooling of the filament affects the oscillations...or the oscillations affect the filament by heating or cooling, changing the resistance, keeping the oscillations constant. Help!
It's been too long, I'm just a mechanical doer nowadays.
:Hi Bill
:Leon
::Bill
:::Hi Norm
:::Thanks Norm.
::::Hi Leon
::::Norm
:::::Leon
:Thanks in advance.
:Leon
