Have you looked at the schematic? Voltages are shown.
http://www.nostalgiaair.org/PagesByModel/982/M0040982.pdf
Several binding posts are tied together because more than one wire connect to these. A+ would also be B-. "A" voltage is for filaments, around 5 1/2 to 6 volts. "B" detector should be lowest plate voltage, usually 22 1/2 to 45 volts. B+ amp would be 67 1/2 to 90 volts. Go by the schematic and you won't have a problem
:The binding posts on my masterpiece have me confused as to what Voltage to connect where. Looking from the front
:of the unit from the left the 7 posts are labeled....... 1 aireal 2 gnd 3 A- 4 A+ 5 A+ 6 B+ Det. and 7 B+ Amp
: both A+' s are tied together as are gnd and A- I thought these were wring but it apears to be original wiring and I
:double checked it against a bottom view picture from another unit and they match. by the way all the schematics I'v seen don't even show the 1/4 inch loud speaker jack. is minecorrect and What power should be put to what post ? thanks
:Jack
:Hi Jack
: Have you looked at the schematic? Voltages are shown.
:http://www.nostalgiaair.org/PagesByModel/982/M0040982.pdf
: Several binding posts are tied together because more than one wire connect to these. A+ would also be B-. "A" voltage is for filaments, around 5 1/2 to 6 volts. "B" detector should be lowest plate voltage, usually 22 1/2 to 45 volts. B+ amp would be 67 1/2 to 90 volts. Go by the schematic and you won't have a problem
::The binding posts on my masterpiece have me confused as to what Voltage to connect where. Looking from the front
::of the unit from the left the 7 posts are labeled....... 1 aireal 2 gnd 3 A- 4 A+ 5 A+ 6 B+ Det. and 7 B+ Amp
:: both A+' s are tied together as are gnd and A- I thought these were wring but it apears to be original wiring and I
::double checked it against a bottom view picture from another unit and they match. by the way all the schematics I'v seen don't even show the 1/4 inch loud speaker jack. is minecorrect and What power should be put to what post ? thanks
::Jack
Enuf rambling. Anyone seen the schematic for the simpler version? Herman
:Thanks guys, I was alittle unsure about were to connect the B- but should have when I saw the eliminiation of the C voltage was like Crosley did with the Model 51.
:thanks again
: :Also....I don't know how familiar you are with these early sets....... Be sure that if you aren't using a high impedance speaker (produced back when the set was produced, and ranging from about 300 to 2000 ohms), or a high impedance headphone set (same resistance as above), that you use an appropriate audio output transformer for a modern speaker. If you connect a modern low impedance speaker directly to the headphone jack, it won't work.
::Thomas
:::Hi Jack
::: Have you looked at the schematic? Voltages are shown.
:::http://www.nostalgiaair.org/PagesByModel/982/M0040982.pdf
::: Several binding posts are tied together because more than one wire connect to these. A+ would also be B-. "A" voltage is for filaments, around 5 1/2 to 6 volts. "B" detector should be lowest plate voltage, usually 22 1/2 to 45 volts. B+ amp would be 67 1/2 to 90 volts. Go by the schematic and you won't have a problem
::::The binding posts on my masterpiece have me confused as to what Voltage to connect where. Looking from the front
::::of the unit from the left the 7 posts are labeled....... 1 aireal 2 gnd 3 A- 4 A+ 5 A+ 6 B+ Det. and 7 B+ Amp
:::: both A+' s are tied together as are gnd and A- I thought these were wring but it apears to be original wiring and I
::::double checked it against a bottom view picture from another unit and they match. by the way all the schematics I'v seen don't even show the 1/4 inch loud speaker jack. is minecorrect and What power should be put to what post ? thanks
::::Jack
