Testing 866 JR on Hickock 533A
8/23/2004 5:37:31 PMPaul
Greetings- Just picked up a pair of Taylor 866Jr rectifiers and thought that I could test them on my Hickock 533A because the chart lists the 866A. However, on closer examination, the chart says 4.3 volts for the filament which I thought was 2.5 volts @ 5 amps. In any case, can this 866jr be tested on my Hickock, and if so, what are the correct settings? ( the 866jr doesn't have a top cap like the 866A). Thanks very much. Paul
8/23/2004 10:57:19 PMNorm Leal
Hi Paul
An 866A has a 2.5 volt filament which draws 5 amps.. It's the 5 amps which is a problem. Due to internal drop of the wiring in your tester it needs to be set to 4.3 in order to have 2.5 volts at filament pins.
866 Jr is a little better. It has a 2.5 volt filament @ 2.5 amps. 866 Jr uses 4B basing, same as an 81 tube but can supply more current. Set it up as an 81 wwith 2.5 or 3 volt filament. Change loading to what an 866A uses on your tester. Don't know your specific tester settings but you will know if it's good by a blue glow and meter reading.
:Greetings- Just picked up a pair of Taylor 866Jr rectifiers and thought that I could test them on my Hickock 533A because the chart lists the 866A. However, on closer examination, the chart says 4.3 volts for the filament which I thought was 2.5 volts @ 5 amps. In any case, can this 866jr be tested on my Hickock, and if so, what are the correct settings? ( the 866jr doesn't have a top cap like the 866A). Thanks very much. Paul
8/24/2004 9:03:38 PMPaul
:Hi Paul
: An 866A has a 2.5 volt filament which draws 5 amps.. It's the 5 amps which is a problem. Due to internal drop of the wiring in your tester it needs to be set to 4.3 in order to have 2.5 volts at filament pins.
: 866 Jr is a little better. It has a 2.5 volt filament @ 2.5 amps. 866 Jr uses 4B basing, same as an 81 tube but can supply more current. Set it up as an 81 wwith 2.5 or 3 volt filament. Change loading to what an 866A uses on your tester. Don't know your specific tester settings but you will know if it's good by a blue glow and meter reading.
Norm- Thanks once again for your invaluable information.I set up the tester just as you had suggested and sure enough we've got a beautiful blue glow along with a great test result. Also glad to learn thar JR only draws 2.5 amps, as NJ7P web site lists it as drawing 5 amperes. Paul
