After seeing Brad's responce looked up your serial number, N133789. It crosses over to chassis 5621 which can't be right. This is a battery operated radio with 19, 2-15, 6A7, 75 & 76 tubes.
Does it look like someone rewired your radio? Was a power transformer added? Are tube sockets mounted with screws instead of rivets?
:::Hi All , I aquired a Zenith tombstone model zenith which needs alot of work , but have no clue to what model it is, the chassis tag number I typed into the oricle site to ID it, but it says should be a 12 tube model??? this is only a 6 tube chassis, I looked around at various models on the NA resource site but no luck the closest I found was a 6s256, but the tube line up shows a 6f5 this radio line up is 5y3, 6a8, 6f6, 6h6, and 2- 6f7 tubes the chassis says n-133789
:::can anyone ID this model? Are these the numbers on the tubes or on the sockets underneath? A strange tube line-up,I looked in my Mallory book and could not find that line-up.Brad
:::Thanks
Here is a schematic.
http://www.nostalgiaair.org/PagesByModel/037/M0025037.pdf
Looks like those 6F7's should be 6K7's. That makes sense.
::Hi Elton
:: After seeing Brad's responce looked up your serial number, N133789. It crosses over to chassis 5621 which can't be right. This is a battery operated radio with 19, 2-15, 6A7, 75 & 76 tubes.
:: Does it look like someone rewired your radio? Was a power transformer added? Are tube sockets mounted with screws instead of rivets?
:::::Hi All , I aquired a Zenith tombstone model zenith which needs alot of work , but have no clue to what model it is, the chassis tag number I typed into the oricle site to ID it, but it says should be a 12 tube model??? this is only a 6 tube chassis, I looked around at various models on the NA resource site but no luck the closest I found was a 6s256, but the tube line up shows a 6f5 this radio line up is 5y3, 6a8, 6f6, 6h6, and 2- 6f7 tubes the chassis says n-133789
:::::can anyone ID this model? Are these the numbers on the tubes or on the sockets underneath? A strange tube line-up,I looked in my Mallory book and could not find that line-up.Brad
:::::Thanks
:Hi all I found it it, shown as a model 6s26 or 6s52
:yes the tube sockets are marked for these tubes, I just can't figure out why the serial number is so far off? it is riveted to the chassis!! but anyway the info I found even the diagram of the top of the chassis matches perfectly
:go figure???
