Zenith Saturn Dial Radio
8/11/2004 7:28:06 PMKen
I received a zenith radio with the model Y733 on the bottom. I need information on this radio, as much as possible.
8/11/2004 9:36:14 PMNorm Leal
Hi Ken
Zenith Y733 is in Sam's Photofact #339-17, around 1956. You should be able to get this through your local library. If not call Sam's @ 800-428-7267. Library will probably be free, Sam's charges for information.
:I received a zenith radio with the model Y733 on the bottom. I need information on this radio, as much as possible.
:Thanks
8/12/2004 11:55:35 PMKen
:Hi Ken
: Zenith Y733 is in Sam's Photofact #339-17, around 1956. You should be able to get this through your local library. If not call Sam's @ 800-428-7267. Library will probably be free, Sam's charges for information.
::I received a zenith radio with the model Y733 on the bottom. I need information on this radio, as much as possible.
::Thanks
8/12/2004 11:59:11 PMKen
Hi Norm,
Thanks I'll look it up at the library.
:Hi Ken
::Thanks
