Plates should not glow red. Something is overloading the 5U4. Not a tube problem. Do electrolytic filter caps have a high enough voltage rating? Is their polarity corrent?
:Hi I'm building a new guitar amp with a 5U4 rectifier. Wired as far as the power section only and thought I'd bring it up on the variac. 3 x 33uF with a 10K 5W and a 5K 5W seperating. The 5K first. Anyway as I was bringing it up on the variac I noticed the plates on the 5U4 starting to glow red in spots.. So I shut it down quick. Is it because the rest of the circuit is not on it ie a load,, or should I be able to fire it up to max on the primary with no load atached.. It's a Sovtek 5U4 maybee it's a cheap tube... THanx
Thanx
Bubba
:Hi
: Plates should not glow red. Something is overloading the 5U4. Not a tube problem. Do electrolytic filter caps have a high enough voltage rating? Is their polarity corrent?
::Hi I'm building a new guitar amp with a 5U4 rectifier. Wired as far as the power section only and thought I'd bring it up on the variac. 3 x 33uF with a 10K 5W and a 5K 5W seperating. The 5K first. Anyway as I was bringing it up on the variac I noticed the plates on the 5U4 starting to glow red in spots.. So I shut it down quick. Is it because the rest of the circuit is not on it ie a load,, or should I be able to fire it up to max on the primary with no load atached.. It's a Sovtek 5U4 maybee it's a cheap tube... THanx
