I have similar circuits somewhere around here. The circuit is called "space charge". By connecting a positive voltage on grid #1 it causes a tube to draw current.
To make this circuit use Grid #2 as input and connect grid #1 to B+, around 9 volts.
Here are some interesting, simple radio circuits. Didn't see space charge mentioned but a person could reverse connections between grid 1 & 2 and use low voltage for B+.
http://vintageradio.me.uk/radconnav/valvetrf/
:Sometime, perhaps between 1945 and 1950, I read an article on building a one tube regen radio using a 1Q5GT tube. It was unique in that the input was applied to the screen grid and the B+ was only 6 volts. I built the radio-it worked, and started my careeer as an electronics engineer and lifelong ham operator. I would really appreciate locating and owning the original article, so I can build the radio again.
:73,
:Sam
:Hi Sam
: I have similar circuits somewhere around here. The circuit is called "space charge". By connecting a positive voltage on grid #1 it causes a tube to draw current.
: To make this circuit use Grid #2 as input and connect grid #1 to B+, around 9 volts.
: Here are some interesting, simple radio circuits. Didn't see space charge mentioned but a person could reverse connections between grid 1 & 2 and use low voltage for B+.
:http://vintageradio.me.uk/radconnav/valvetrf/
::Sometime, perhaps between 1945 and 1950, I read an article on building a one tube regen radio using a 1Q5GT tube. It was unique in that the input was applied to the screen grid and the B+ was only 6 volts. I built the radio-it worked, and started my careeer as an electronics engineer and lifelong ham operator. I would really appreciate locating and owning the original article, so I can build the radio again.
::73,
::Sam
