See the 46-420 schematic right here on this site in thr RESOURCES section. Link is at top of page.
http://www.nostalgiaair.org/PagesByModel/597/M0013597.pdf
Just a quick comment.. You mention 160 volt rating on this cap. Use a 600 volt cap here. This is audio output and there can be large voltage swings at this point.
::On the 50L6 tube there is a .02mfd@160VDC connected to pin #3.. Where does the other side of the capacitor go? Does it go to another tube pin or to ground? Thanks in advance.
:See the 46-420 schematic right here on this site in thr RESOURCES section. Link is at top of page.
:http://www.nostalgiaair.org/PagesByModel/597/M0013597.pdf
:Hi
: Just a quick comment.. You mention 160 volt rating on this cap. Use a 600 volt cap here. This is audio output and there can be large voltage swings at this point.
:::On the 50L6 tube there is a .02mfd@160VDC connected to pin #3.. Where does the other side of the capacitor go? Does it go to another tube pin or to ground? Thanks in advance.
::See the 46-420 schematic right here on this site in thr RESOURCES section. Link is at top of page.
::http://www.nostalgiaair.org/PagesByModel/597/M0013597.pdf
