5M3 Schematic Q
6/4/2004 5:48:51 PMLee
Greetings,
Boy could I use a hand here.... I'm trying to recap a nice old 5M3 and all of the schematics I have found do not match the parts lists. Example, where does item 49, 50 or 45 match up with the schematic!? Does anyone have a real Crosley service manual for this little tombstone? YIKES.
Best, Lee
6/4/2004 6:38:52 PMNorm Leal
Hi Lee
That schematic in Rider sure looks like a Crosley print. They numbered everything instead of listing values. I couldn't find those items either. Are parts marked in your radio? See if you can go by values already in your radio?
http://www.nostalgiaair.org/PagesByModel/517/M0003517.pdf
:Greetings,
:Boy could I use a hand here.... I'm trying to recap a nice old 5M3 and all of the schematics I have found do not match the parts lists. Example, where does item 49, 50 or 45 match up with the schematic!? Does anyone have a real Crosley service manual for this little tombstone? YIKES.
:Best, Lee
6/4/2004 9:06:16 PMSteven in Oregon
Lee
In the parts list, these part numbers seem to represent two section caps with one common connection
45-46 .1 mfd (x2) at 200v
47-48 and 49-50 .02 mfd (x2) at 200v
The following caps on the schematic have no coresponding part number in the Rider's parts list
10-11 \
12-13 I'm pairing these off since they also have common connections.
14-15 /
My guess (and it's nothing more than a guess) is that these parts were re-numbered by a Crosley engineer. Rider might have an early version schematic and a late version parts list. I would bet (and this is also just a guess) that they corespond to each other in numerical order: i.e., 10 & 11 = 45 & 46, 12 & 13 = 47 & 48, and 14 & 15 = 49 & 50.
One more guess: It could be that parts 10 thru 15 were originally individual caps, not two-section caps.
:Hi Lee
: That schematic in Rider sure looks like a Crosley print. They numbered everything instead of listing values. I couldn't find those items either. Are parts marked in your radio? See if you can go by values already in your radio?
:http://www.nostalgiaair.org/PagesByModel/517/M0003517.pdf
::Greetings,
::Boy could I use a hand here.... I'm trying to recap a nice old 5M3 and all of the schematics I have found do not match the parts lists. Example, where does item 49, 50 or 45 match up with the schematic!? Does anyone have a real Crosley service manual for this little tombstone? YIKES.
::Best, Lee
