This is a battery-operated 45 RPM record player with an AM radio. It's in a brown leatherette-on-wood case, which measures 11" deep, 8 3/4" wide, and 4 3/4" high. The top opens to reveal a cute little 45 RPM turntable, volume control with power switch, a radio tuning dial with Conelrad markings,and a slide switch to select radio or phono. The tone arm is metal, with a gray hammertone finish.
There are no other identifying marks on the unit, inside or out. It was made in USA, as many components on the 2 circuit boards inside are marked 'made in USA.' There are three transistors on the radio tuner board, and three transistors on the amplifier board. The front of the unit has a gold-tone metal trim, with a carrying handle that is clear plastic with a bent metal rod embedded in it, and a gold metallic grille cloth. The unit is powered by 4 D cells, which go into a cardboard tube accessed via a small cover plate on the back.
Other than needing some cleanup and a new drive roller (it has a flat spot), it works perfectly. Looks like something that a teenager would have had in the 50's or early 60's. Must not be many of them around, because I can't find anything on it in any of my usual resources. Anybody recognize it?
D.
Dennis
