See if this answers your parts questions?
http://www.philcoradio.com/tech/images/95.jpg
10 mfd @ 450 volt electrolytic caps work well. Leave out that one across the choke.
:Help!!
: Where can I find list of parts by part number for the Philco 95? I need values for capacitors inside round tubes labeled "Philco part No. 3787A", "Philco part No 3788A", "Philco part No. 3788B" and the two flat metal cans mounted on the side. I know the part No 3787A also has 250 ohm wire resistors and I have found two different capacitor values listed.
: I found "Philco part No. 3754" Capacitor block values for 60 hertz filter in Riders for Model 112 and they check out with values found on marked up schematics. Instead of a 0.15 mfd across the filter choke and 2.0 mfd electrolytics on each side, I intend using 10mfd, 450V electrolytics.
3788A is .015 3787A is .05 3584C is .05
3584B is .05
3788B is the same as 3584C and B
If you want a full schematic with the resistors and the
Colors and a Chassis display E/Mail :
philcorestorer@aol.com
NEVER A CHARGE FOR PHILCO INFORMATIOIN
::Help!!
:: Where can I find list of parts by part number for the Philco 95? I need values for capacitors inside round tubes labeled "Philco part No. 3787A", "Philco part No 3788A", "Philco part No. 3788B" and the two flat metal cans mounted on the side. I know the part No 3787A also has 250 ohm wire resistors and I have found two different capacitor values listed.
:: I found "Philco part No. 3754" Capacitor block values for 60 hertz filter in Riders for Model 112 and they check out with values found on marked up schematics. Instead of a 0.15 mfd across the filter choke and 2.0 mfd electrolytics on each side, I intend using 10mfd, 450V electrolytics.
Jerry
::Hi Jerry
:: See if this answers your parts questions?
::http://www.philcoradio.com/tech/images/95.jpg
:: 10 mfd @ 450 volt electrolytic caps work well. Leave out that one across the choke.
:3788A is .015 3787A is .05 3584C is .05
:3584B is .05
:3788B is the same as 3584C and B
:If you want a full schematic with the resistors and the
:Colors and a Chassis display E/Mail :
:philcorestorer@aol.com
:NEVER A CHARGE FOR PHILCO INFORMATIOIN
:::Help!!
::: Where can I find list of parts by part number for the Philco 95? I need values for capacitors inside round tubes labeled "Philco part No. 3787A", "Philco part No 3788A", "Philco part No. 3788B" and the two flat metal cans mounted on the side. I know the part No 3787A also has 250 ohm wire resistors and I have found two different capacitor values listed.
::: I found "Philco part No. 3754" Capacitor block values for 60 hertz filter in Riders for Model 112 and they check out with values found on marked up schematics. Instead of a 0.15 mfd across the filter choke and 2.0 mfd electrolytics on each side, I intend using 10mfd, 450V electrolytics.
