A radio has at least 2 electrolytic filter caps. You mentioned a 47 mfd. There should be another one. When they are replaced at least one lead of the old one should be removed.
Electrolytic filter caps dry out over time and allow hum. They can also short and damage other components in a radio.
:I have an RCA model 4QR64X radio made in west Germany.So far have not been able to find schematic.
:Plays great and I love the eye tube. The three sw bands
:seem to be very sens.Problem is hum (120) cycle I think.Has variable trans for diff voltages.Tubes are
:6X4,6BE6,6BA6,6AU6,6AQ5 and EM34.New tubes and 47 Mf
:cap has been replaced (added?)Hum just a little to loud for comfort.Not affected by volume or tuning
:control.Ant is long wire. Help.
You can always use a cap with higher voltage rating. Using a slightly higher capacity is also ok.
A cap with low voltage rating wouldn't be a power supply filter. I would expect a voltage rating of several hundred volts?
::Hi Robert
:: A radio has at least 2 electrolytic filter caps. You mentioned a 47 mfd. There should be another one. When they are replaced at least one lead of the old one should be removed.
:: Electrolytic filter caps dry out over time and allow hum. They can also short and damage other components in a radio.
:::I have an RCA model 4QR64X radio made in west Germany.So far have not been able to find schematic.
:::Plays great and I love the eye tube. The three sw bands
:::seem to be very sens.Problem is hum (120) cycle I think.Has variable trans for diff voltages.Tubes are
:::6X4,6BE6,6BA6,6AU6,6AQ5 and EM34.New tubes and 47 Mf
:::cap has been replaced (added?)Hum just a little to loud for comfort.Not affected by volume or tuning
:::control.Ant is long wire. Help.
:::Found another small metal electrolytic marked
:25uF but I don't understand voltage seems to be
:12/15V- Found similar one marked west Germany
:32uF/150v- is this an ok replacement?
I found this same radio in my dad's attic. Can you tell me how old it is. Mine works fine but was wondering any information you could give me about it. I like the tuning eye too!!!!
